Clutch problems
Congrats Jeremy! Glad you finally got it straight. How are the second gear pulls now?
Unfortunately I was unable to get on the car or get into boost yet, looks like my frps is bad, I was only getting 10-20psi of fuel pressure, just enough to go part throttle and cruise.
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
Hmmm...and Luke is having his 410's removed soon for his turbo....guess Eddie is going to be making some $$$.
Yeah I already mentioned to Luke that I am interested in his 4.10s, too bad he already has the 3.55s to go back in, then we could just do a rear swap lol
Okay so the rst I got from JPC does have a part number on the fingers. Just couldnt see it in the picture i took at night when i got it.
6912-00?
Here is a shot of the fidanza and mcleod steel flywheels side by side the dimensions are identical.
one eyed willy
Pizzle fo shizzle
Lakeland FL
mine is a 6913, on a mcleod flywheel...my floater ring is no where near as big as yours.
i also stumbled accross soemthing somewhere about how the top and bottom discs where coming from the manufacturer with incorrect specs.
gil_t2
Love Nitro in the Morning
Northern Va
6912 is for Mcleod flywheel, 6913 is for STOCK flywheel (small dia ) not for s197
BrandMcLeod RACINGManufacturer's Part Number6912-07Part TypeClutch KitsProduct LineMcLeod RST Street Twin Clutch KitsSummit Racing Part NumberMCL-6912-07Input Spline Quantity26Input Shaft Diameter1.125 in.Disc Diameter (in)9.688 in.Disc Diameter (mm)246mmDisc MaterialOrganicDisc StyleSprung hubPressure Plate StyleLongThrowout Bearing IncludedNoAlignment Tool IncludedYesPilot Bushing IncludedNoFlywheel IncludedNoCounterweight AssistNoMounting Hardware IncludedNoQuantitySold as a kit.NotesDesigned to fit 164, 176, 180, or 184-tooth flywheels. Will not work with factory flywheel if If the center hub of the flywheel is recessed
http://mcleodracing.com/products/RST+Twin+Disc.mcl?rsku=16166
AutoXRacer
Florida
After 21 pages of posts, what was the outcome?
Is the McLeod clutch issue fix still a mystery? Is it a simple shim up the throw-out bearing/slave or is it more involved?
You can add me to the list of McLeod RST owners with shifting issues.
Just wondering what the fix is.
No one has contributed to this thread for almost a month...
My fix was an act clutch. I didnt have shifting issues the clutch just wouldnt disengage. The rst is at mcleod and im waiting to hear back from Justin on what mcleod has to say.
AutoXRacer
Florida
I was thinking about the same exact fix... Twin disc or single? I'm thinking of a single.
Please let us know what McLeod comes back with...
I just hate to think about tossing a $1,200 clutch. sigh
redstangs9308gt
Are you going to be doing the work yourself? If you are and don't mind the work I would take it apart and try a 30 dollar shim. Worst cause you drank alot of beer and wasted a weekend. Are you on a 3650 or 6060?
AutoXRacer
Florida
If I was going to do it myself, I would have tried the shim fix already!! But I have to take it to a dealers/shop since I don't have a garage.
Whats a 3650 or 6060...?
I'm on the stock 5 spd.
