i think the strategy has to match up for the tunes. whenever you go to download a new tune to your handheld, it always extracts a copy of the original, and the two "base" strategies (the way i understand it) need to match up, or i don't think it will download to your hand held.
i'll check my downloaded tune files this evening to see what i have in there, but i may have deleted all of them after installing the cams and delete plates. i see yours is an 07gt, it may work for you if i still have one left over, i think.
if i do have one you'll probably have to go into the parameters and adjust for gear and tire size, since the base file will be set for 4.10s and a 26.6 tall tire.
as fast as your car goes stock, it'll probably screw you up!
edit: all of my tune files will be with the airaid cai with the insert removed.....this probably won't work with your cai. the airaid cai without the insert is about a 105mm maf when it's all said and done. that probably won't work with your set up. i can still send it to you and you can try it out, if i have one still.
just pm me your email, and i'll send anything i have that might come close to working. if it won't work because of the size of the maf, you'll know right away...it'll barely run at all.
