saleen836
Took the plunge and ordered the MGW flat stick shifter based on the "cult like" following it seems to have - really couldn't find a bad review. Considered Steeda and really almost bought the Barton as it has a "cult like" following with the challenger crowd (and a similar story to MGW as far as the company goes). Will be installing that, along with an FRPP aluminum one piece driveshaft I just received.....going to tackle the spark plug replacement too (fingers crossed). If I get done "early" I may do cams, but at 76k on the motor, I would think I should do the timing components too. Opinions?
Looking to purchase the MGW shifter for my 06 Saleen, OP did you have any interference problems with the shifter kit and 1-piece prop? is your car lowered? as MGW when I spoke with then recently informed me the max diameter for driveshaft is 3.5" to avoid interference but if the car is lowered this might cause a problem
