R3SonicBlueGT
I apoligize for the uproar. After seeing the last post I went back to look at my post. I meant 370 RWHP. Sorry to get everyone BP up. My bad, fat fingered the number.
Cool and Good Luck to you. Welcome!I apoligize for the uproar. After seeing the last post I went back to look at my post. I meant 370 RWHP. Sorry to get everyone BP up. My bad, fat fingered the number.
Here are some calculations for you guys. These are the numbers i look for with my car and they may or may not help you. The lowest rpm my car sees in a race is usually 4800-5000 (2-3 shift) so i look at numbers from 5k-6.8k (still on stock springs). Here are the average hp results from that MM&FF test, starting at 5k and taken every 300 rpms till 6.8k. (all numbers are obviously crank)
Stock 3v- 343hp
Stock w/intake- 347hp
Intake/Cams- 373hp
H/I (stock cams)- 367hp
H/C (stock intake)- 344hp
H/C/I- 378hp
again, this is the average crankshaft hp from 5k-6.8k.
I wanted numbers too but after months of not much i decided to purchase the intake myself. My car laid down 330/314 with stage 2 nsr's, pypes LT's, or/h, mac mufflers, delete plates, udp's, tune, 4.10's, C&L racer.
Only thing i have changed is i switched to an or/x and borla mufflers. I have the intake and when snow clears, i will dyno it on the same dyno. Should be around april.
Cams and heads got me 51 RWHP thru an Auto when I had my 281.Stick or auto? What dyno? STD or SAE?
No fucking way cams and heads gets you 130 hp...BULL FUCKING SHIT.
^ read the article smart guy. Numbers are form an engine dyno. think before you post. (meant for lightblade)
and redfire, i believe i mentioned that more than once lol.
Stock 3v- 343hp
Intake/Cams- 373hp
H/C/I- 378hp
, although even when you do that the air comes out crooked.I have had my hands on a few of them, From what i have seen its worth about 10-15hp n/a and about 20-30hp FI. I have never put one on a complete stock un modded car to test the gains if any though
make 240-270 to the wheels stock
