FRPP intake manifold with turbo?
MrBhp
I've dug around in some of the older threads but couldn't find a specific answer to my question. How good is the stock intake manifold on a 4.6 3V. I will be running 9lbs or so on the stock block. Will turn it up when the forge assembly goes in. Any thoughts? I'm thinking of getting the FRPP intake, or maybe the Steeda delete plates.
Badd GT
wake forest nc
My experience with the FRPP was that it did not perform as well as the stock intake with deletes. This was in NA form. Never tried it with any type of FI, but others who did showed gains over the stock intake with deletes. IIRC BruceH documented some of his results, might try searching under his name
MrBhp
Cool. Thanks!
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
I have the stock intake on mine. I will not go to the Ford Racing intake as the torque loss for normal driving is too much for me. The loss in torque at low-mid rpms will also mean slower spool times.
There are hundreds of things I would spend my money on before an intake that only improves things past 5500 rpms after making them worse prior to that.
RED09GT
BruceH's car only saw improvements with the intake when he had it on the big bore stroker motor. He even put the stock intake back on the big bore motor and it gained a bunch of mid-range power but did lose some up top on that combo.
MrBhp
That is exactly what I was looking for. Couldn't find bruceh posts. Search really sucks. Thanks. I'll get some delete plates and go from there.
Dino Dino Bambino
I have a red car
Cyprus
The stock Intake manifold with delete plates produces more mid-range torque (3300-5200rpm) whereas the Ford Performance intake does better at higher rpm (5200+). Below 3200rpm it's a toss up between the two.
On a turbo set up I'd say the Ford Performance intake with twin 62mm TB will work great. Peak TQ will be slightly lower than with the stock manifold/delete plates but the torque curve will extend further at higher rpm making it flatter, and that obviously means more HP.
myystanng
I shove the frpp with a turbo and made 760 wheel on 16 psi.
Never tried the stock manifold though
I also have a big bore so the toqure issue was not as bad for me
Jason Mathews
I would upgrade to the ford performance milk jug. It also deletes the imrc that you have to delete if going boosted like me. Its tested to 25 psi i believe
Sactown
Sactown
Sacramento, CA
I have been running the FRPP intake for a number of years now, but I don't drive my car on the street unless just going around the block. The boost on my car is 24-26psi, no issues
MrBhp
Thanks guys. For now I'm going to run the stock intake with delete plates. When I get the stroker ready I'll switch over to the frpp piece.
