Pick up some low mile takeoff injectors from the classifieds, would be cheap and easy way to freshen them up.
Hummm....Pick up some low mile takeoff injectors from the classifieds, would be cheap and easy way to freshen them up.
Most places reccommned having fuel injectors cleaned or serviced every 25-30k miles. There are lots of factors that play into that though.
If I'm crusing on the highway and drop to 3rd my car will hiccup really bad then go. I'm running 340rwhp so roughly 380-400 crank and still got a few more mods coming long tubes and more. Did the math and calls for 27-30lb and has my 24lbs running at max. 2006 3v. Will be upgrading fuel pump to a walbro 405lph. Stick with stock 24's or go bigger?
What delta did you calculate at? The stock tune will command up to 70 psi with higher airflow. This makes the injectors able to support a whole lot more power than the standard 3 bar psi used by most calculators.
The 5.0 takeoff injectors work well and are well priced. The old 39lb blue cobra injectors work well for a budget price too.
Delta? What size are 5.0 injectors? Im cammed exhaust and a CAI and brenspeed tune. I do believe the stock fuel pump has a good play in whats happening but its so often and will be that hesitation and a hiccup when I drop it like that. I'll have to datalog it but already going to a walbro pump from S&H. And thanks guys
Quite sure your problem will still be there with the new pump.
