Snakethat
JLT Cold Air Intake had to upgrade it from my orginal saleen CAI
3.0 pulley
Belt
All the B302 Bearings
Laser Cut Windage Tray
FRPP Upgraded GT500 HV Pump & Pickup
Oil Pan Gasket
ID Injectors 72lb
Input Shaft
New 1 step colder spark plugs
Comp Valve Springs/Retainers
timing chains
gaskets
Ford Head Gasket Pair
> Ford Head Bolts
> Ford Oil Pan Gasket
> Ford Cam Phasers Bolts
> Ford Timing Chains (pair)
> Ford Bell Housing Dowell Pins (2)
> Ford Front Cover/Rear Main Dowell Pins (4)
> OEM Crank Bolt
> PA 8 Bolt Flexplate
> ARP Flexplate Bolts
so this is everything I have purchased
Am I missing anything
3.0 pulley
Belt
Oil Pan Gasket
ID Injectors 72lb
Input Shaft
timing chains
gaskets
> Ford Head Bolts
> Ford Oil Pan Gasket
> OEM Crank Bolt
> PA 8 Bolt Flexplate
> ARP Flexplate Bolts
