Learning to make fast go fast!
05stroker
Never enough power guy!
Bullard Tx.
Lol no one rides in the back seat anyway. With what ive seen so far i think you could make it really nice.
Just need top keep the outside looking like the pic in my sig when the 20s go on for the street and the side panels inside the car right?
It would look really cool to look inside the car and there is only .040 aluminum and a drivers seat, no carpet even, just .040 alum on the floor, back seat, and a drivers seat!
05stroker
Bullard Tx.
Got the bracket for the second fuel level sensor made. I also have the heads and delete plates done and the heads will go to the machine shop tomorrow to get milled and the seats ground on the heads. I did the o-ring groves on the block to day as well.
Next week end I will bolt in the crank, with one rod, one piston, and one head to check the piston to valve clearance. After that I will know if the pistons will need an exhaust valve relief or not. Then the pistons and other parts will go to Polydn in Houston to get coated.
I should be putting the motor together in about 2-3 weeks.
05stroker
Bullard Tx.
Pistons and are you having the bearings coated?
Pistons, bearings, crank, rods, Jpc intake, IC piping. I would have to recheck the pricing tomorrow for you. I have the tickets from everything they have ever done for me.
05stroker
Bullard Tx.
Now if I could just find a fuel level sensor like the one on my Fore hat I could go to bed! My internet skills are on fail tonight.
Weou09
Bham, Alabama
That is the fuel level sender that is easy to find. It is the metal one that is rare. That is the exact same one my 07 has. Here is just the sending unit part number W0133-1884211. The second fuel hat you pictured looks just like my CP-e hat which has provisions for either sending unit.
05stroker
Bullard Tx.
Thanks!!! I guess I should have zoomed in on the online pictures with it in the bracket it looks nothing like what I have. It'll be here tomorrow.
05stroker
Bullard Tx.
Got the fuel level sender mod done today and the pump mounted in the cell. I decided to modify the factory bracket that came with the pump instead of using the alum. one I built. It was pretty easy and I used stainless steel hardware to bolt it up. I bent the arm and inserted it into the float on the other sender so there is only one float. Looks much cleaner IMO. Tomorrow I can finish up the fuel lines and wiring and bolt the cell down.
