Learning to make fast go fast!
05stroker
Never enough power guy!
Bullard Tx.
Should be running in about 30 days and to the track in mid April, Lito has been put on notice for tuning and the ID2000 injectors should ship this week. I am starting to think about weight saving mods and loose the whole street car thing though. Recent events have mad me rethink what I want to do with the car. The end result is to go as fast as I can after all. I have a few decisions to make really soon. Should be a great year to go fast!
Doug M
Fast Cars & Freedom
AL. Baby
I hear you Billy. Sounds like you're about to have lots of fun. Just go as fast as possible Brother:) While you can.
dysan
Dis-Member
Williamstown, N.J.
I really think you need to consider a different trans at this point. I believe you are going beyond what the 4R70W can handle and if you are thinking of going more race and less street, it really comes down to either a TH400 or glide. The choice between those two really depends on how light you can get the car if you do lighten it.....if it is 3500+ lbs I would say the TH400 but if you can manage to get the weight lower than 3500 then the glide would most likely be your best bet.
05stroker
Bullard Tx.
Thanks for the input. I will have to see how things go this year with the new power and the 4r70w first though.
05stroker
Bullard Tx.
I mocked up the crank, couple rods, and pistons tonight and am ready for the heads to get back here on Wed. so I can check the clearance with the heads milled down. After that I will know if the exhaust reliefs will be needed or not. I really don't think there will be a need since the heads are minus .020 and the head gaskets are .043 vrs the factory .036. If you look in the pics below you will see that the old -18cc pistons have a flat edge around the pistons the same as a flat top.
dysan
Dis-Member
Williamstown, N.J.
The reason I brought this up is for your safety...the last thing I want to read about is a crash from the case blowing apart on your trans and the fluid getting under your back tires on a high speed pass.
I've seen cars at the track spill fluid and wreck majorly...don't want to have that happen to you.
Department Of Boost
Alpha Geek
Sounds spensive
05stroker
Bullard Tx.
Please remove all tools from the engine.........
Yea right, especially if its a crescent wrench from AutoZone! LOL
My last time at the track I had forgotten to tighten the clamp on the lower radiator hose! Well, it came off and I was looking at the wall from an angle I don't ever want to see again. Maybe a diaper or belly pan made from allum. is in order. IDK
Sounds spensive
Removing parts cost nothing... haha
