Marc S build version 6.0
Marc s
NASA AIX
Auburn, WA
It measures 32" x 18.5" x 4".
The nice thing for me is, the inlet, outlet, and water temp location is designed for the Yates engine.
Marc s
NASA AIX
Auburn, WA
Well, the engine is in it's new home. Now I have to install the trans, set the tailshaft angle and build a rear crossmember. After that, I might even remove the ratchet strap.
Oh ya, like I suspected, the hood doesn't shut. LOL.
Marc s
NASA AIX
Auburn, WA
I take it back, the hood closes but the carb is touching the hood. I need to see if a Tiger Racing hood has more clearance. If not, I will buy a cowl hood.
Marc s
NASA AIX
Auburn, WA
I also had to modify the BMR K member rack mounts. The dry sump pan hit the rack before the engine mounts came to rest. After the modifications, the rack sits 1" lower and gave me about 1/4" of clearance between the rack and oil pan. This isn't BMR's fault. I'm sure the K member was designed for a conventional oil pan.
