Kooks Highflow CATS!!!
Second set of Kooks Cats I've heard of clogging via the s197forums...
sucks man!
Before everyone starts jumping on the "Kooks Cats Suck" bandwagon perhaps everyone needs to question why these cats were clogged or failed.
I really wish I knew that!!! It's like one question answered, then another one arises!
Still nothing good to report. No more backfiring. But still whenever I go past 1/4 throttle the car bogs down and doesn't move anywhere.
So I got gas, came home and swapped out all 8 coil packs. Went for another drive and same thing. Datalogged this trip to see what was going on. I did manage to hit 13lbs of boost so why I am not going anywhere I have no idea...
Plugged cat? MAF plugged in/sensor still good? Good luck man...
I just blew my motor.
So many mods at once it will be difficult to figure out what went wrong. Didn't I read somewhere where you had flames shooting out the tail pipe upon initial start up? Sounds like ArizonaGT guessed or knew several pages back.
I know it is difficult to blame Kooks, but come on its only a cat. A simple non-moving object and should not have failed the way it did. Unless someone can point to a specific cause of causing a cat to fail, I have to conclude the product failure of the cat, either is design, materials or craftsmanship. Good luck man!
So glad i ditched my cars when i bought LT's.. That shit is crazy..
And #16... ahhh, such fond memories.
Bruce check out these websites. May help to determine why your cat failed:
http://www.catalyticconverter.org/failure/index.htm
http://www.car-sound.com/04basics/04failures.asp
http://www.ansaautomotive.com/Library/tech/ansa_automotive_catalytic_converter_failure.pdf
