ZEM
325/40's mounted..........MUCH BETTER, I should of just did these the first time around!!
before with 275/45/18
and after 325/40/18
and after 325/40/18
That's big different in the sidewall. How much wider is the tread?
You have 10 inch wheels, correct?
Technically, "doing the math" will tell you the section width, not the tread width. And that is only accurate on a specific rim width. But, in reality, many tires are not exactly as rated, and M&H has always been one of those that are off.not really, its only 7MM difference if you do the math
Having said that, according to M&H, there is about 1.8" difference between the tread widths of the two, and 1.9" on the section width. The pics above would seem to confirm the expected 1.9" difference.
did you get these on the car yet,im curious how the clearence is.
Do you have any shots with the wheels and tires on the Stang ?!?!?
