Kent
I just finished installing a Kenne Bell BAP on my 07 Mustang GT.Checked and doubled checked wiring.It is installed correctly according to the instructions I received from Brenspeed.
What has me perplexed is they instruct you to turn ignition to on without starting and then turn the controller dial from min to max and listen for the BAP to buzz louder as you increase setting and quieter as you decrease.I can't hear it do anything.I even used the old screwdiver stethoscope method and nothing.What does happen however is when I turn the ignition to on I get a chirp from that area.Is this normal?I can't remeber this happening before.[The chirp that is.]
The car starts and runs.I however have not driven it yet as I was concerned about this and Brenspeed was closed by the time I got this far.Your comments and suggestions will be appreciated.
Thanks, Kent
Thanks, Kent
