46addict
13726548
I would. Otherwise there wouldn't be a clear path for the gases to escape.
Looks like removing the internal pcv is no joke:
http://www.s197forum.com/forum/showthread.php?t=126095
Was that check valve breather store bought? Can you post a link for it?
UPR does as well..I think CFM Performance is the only one to build one with the check valve for boosted cars.
There is no oil on the driver's side breather because there is no vacuum source opening the PCV baffle in the driver's side cam cover.
One catch can needs to go between the driver's side cam cover port and the intake manifold vacuum port. A second catch can should be used between the passenger side port and the intake tube if you want to keep oil away from the intake tracts.
