Unless you intend on running the car mostly for racing or track use, I wouldn't recommend using breathers anyhow.. For daily driver and street use, I really don't think there's any benefit in disabling the factory PCV system in favor of venting the crankcase to atmosphere with valve cover breathers..
Even if the PCV valve is removed by providing 3 paths for venting the crankcase, there still needs to be enough crankcase pressure for pushing the bad air out to begin with, otherwise the majority of crankcase vapors end up remaining in the crankcase causing contamination and eventually shortening the life of your rings and seals..
This is true. You will not get the same effect of clearing out the the vapors. A lot more stuff gets dissolved back into the oil. I change my oil more frequently because of that fact.
I actually ran breathers for awhile to find out just how effective they were over the factory PCV system and although they prevented crankcase vapors from entering the intake manifold and back into the crankcase itself, I found out through personal experience there was nothing coming out of the driver side cam cover because of the PCV valve not being removed first which only allowed for just one path on the passenger side cam cover for venting the crankcase..
So rather than going through the hassle of uninstalling the driver's side cam cover and then by having to cut open the PCV housing tube just in order to remove the valve and hope that nothing goes wrong.. That was just a risk in which I was not willing to take, therefore being that my car is mostly used for street use and isn't taken to the track anyhow, I decided that it was best to just leave the factory PCV system in place and run UPR's latest 4 chamber design catch can/oil separator instead.. So far after 4 months, the UPR separator seems to be doing it's job quite well..
Removing the PCV valve is a simple operation and it is pretty hard to eff it up. I just cut the little baffle plate and bent it back. Cut the line with the pcv valve in it and bent the plate back up. It's not rocket science.
The PCV system is a smog thing. Back in the day all engines had breathers. I've been using breathers for 30+ years on all of my performance motors without any ill effects.
As for running a breather in place of the factory oil cap goes, I also wouldn't recommend replacing the oil cap unless the breather has a one way check valve for preventing un-metered air from entering the crankcase..
What difference does it make? The breather on the oil cap is going to do the same as the other breathers. I mean they all go to the same place. Running a check valve on one is not going to prevent air from entering from the other two breathers. That's kinda silly. Unless maybe you mean running the oil cap breather with a stock pcv system. That would be a no-no. I'm saying if you go breathers you should go with all three instead of the one or two.
Anyway just my $.02..
