06 GT with 31k miles. Just returned fully to stock. It runs through the whole RPM range smoothly, but stumbles between 1500 and 2500 when holding the RPM constant with no load. It gives some grumbling and the car shakes a bit. Under load, the car stumbles almost as if there is a lot of slop in the driveshaft, but there's not. This happens when either at lower speeds in those RPMs, or engine braking through those RPMs. Throwing code P1000 but I figure that's just due to the tune being new. In the video, I'm holding 1900 and 2300 respectively and you can hear the burbles or whatever you want to call them. Any ideas?
