Suggestions: 18/19" Square setups with a lip
GallopingFord
I'm Cam - Mr. Indecisive
Northern Virginia
Back in contact with CCW.
I can do a 18x10 and they will fit with less than 1 degree of camber or I can do the 18x10.5 and do around 2 degrees of camber to keep the top of the wheel at the fender. They can allow a BBK if the lip is a maximum of 1.5"
I cannot decide on the finish though.
Face color: Competition Grey, Hypersilver, or Satin Pewter
Lip color: Matching face, polished, or a brushed anodized.
Jeffk
Thomasville, NC
I can do a 18x10 and they will fit with less than 1 degree of camber or I can do the 18x10.5 and do around 2 degrees of camber to keep the top of the wheel at the fender. They are checking to see if the aggressive offset will allow a BBK.
Damn. Satin pewter with the polished lip would look badass IMHO..
GallopingFord
Northern Virginia
Yeah that would look pretty awesome..
GallopingFord
Northern Virginia
CCW emails back fast. The brembos won't fit without a spacer so I may need to do some deep thinking if I want to remove them in favor of these wheels since I want a 2-2.5" lip. all around.
neema
Fresno, CA
Yeah, that's why I just impulse bought new Shelby SS wheels they just re-released for a last time. :beerdrink:
I ask my self how I manage to save money sometimes.
aw man, ccw's evaded you again?! if you get the SS wheels, get all 20x10s!!! did you go with the polished or black color?
GallopingFord
Northern Virginia
I bought the SS wheels. They only offer them in the Durabright finish. I do not think I will use them on my Bullitt though. I personally only think those wheels look good on the GT500 front end.
Still in talks with CCW. So far we have a came up with a 18x10.5 that does not clear BBK's only stockers and it is finished in satin pewter and I will do a polished lip if it all goes well.
Does anyone know what brake kit is either the same size as the stocker (caliper and rotor) that is upgraded? This is a hard decision.
neema
Fresno, CA
i don't have any empirical evidence, but from what i've observed, the stoptech and saleen calipers look like they're mounted further inboard. i know this because the offset of the brake rotor for stoptechs doesn't match the factory brembo rotor, but they are the same overall diameter (355mm). you may have better luck with those calipers. not all brake calipers are mounted in the same location
GallopingFord
Northern Virginia
I was planning running a 315 all around but after doing research I found I may need the GR 315 kit, so I'm waiting to hear about that.
Kind of doubling back and looking at Jongbloed wheels now. A little bit of overkill, but I did find them for a good price.
DRock
You probably just need coilovers to fit 315s....I'm planning on 305s some camber and the extra room coils give should allow you to do it
