Error404
photographer
Now that I have my D-specs on the front and rear (and other suspension parts, all of which are not adjustable I believe), I'm a little curious to start adjusting the shocks/struts. Something which I didn't think I would really want to do! I see where to adjust the fronts, and I assume the rears would require removing some of the interior panels.
What exactly does the soft/firm settings do, which from what I read it adjusts both the compression and the rebound at the same time? If I adjust them all the way as firm as they go (or as firm as I can handle them on the roads) is this really the best setup for turns? Or is firmer not always better around turns? Does adjusting softer or firmer change the ride height? or only the stiffness of the ride? Will a firmer setting be more or less prone to sliding?
I guess my main question is this: Is firmer always better for handling around turns? or is it only better to a point? If it's only better to a point, how do you tell when you have reached that point? I don't drive on a track or anything, just on country/mountain roads so I don't really ever push the car as hard as it can go. But I'd like to get the best handling for the driving that I do.
I'm not dissatisfied with the feel of the car in anyway, just getting a little curious about adjusting them
Any tips?
Any tips?
