sheizasosay
Alive
- Joined
- Jun 28, 2011
- Posts
- 1,024
- Reaction score
- 4
I just got some whiteline adjustable endlinks for the front sway bar and have installed them on one side and have stopped for now. I'm looking at Steeda's instructions for setup and have a question. For reference http://www.steeda.com/store/uploads/555-1053-1.pdf
I understand you don't want the sway bar loaded unless you're turning and Steeda's instructions on the first part make sense in that respect: Remove both factory endlinks. Install one adjustable endlink. Put the wheels back on and lower the car. From under the car put the other end link on and set it to the length where it effortlessly slides in (strut ear) so as to not preload it. That all makes sense.
Now at the bottom of the instructions it has notes for track or competition use. Here it tells you to adjust the endlinks so they are parallel to the control arm bushing centerlines. It continues to talk about non-linear rate if you don't set it up accordingly.
Seems that would negate the previous instructions if you had to change the endlink lengths. Am I off here? Through searching I have found mostly "get them parallel" to be the norm. I'm leaning towards that. Any help would be appreciated.
