MU55 DEW
- Joined
- Jun 2, 2020
- Posts
- 1
- Reaction score
- 0
Any of you guys can recommend the best air intake system. Im contemplating a Roush but fancy a stainless system like BAA too ??
There is no best, they all flow the same as stock.
What year is your car with the 4.6 ?Any of you guys can recommend the best air intake system. Im contemplating a Roush but fancy a stainless system like BAA too ??
On a stock 3v engine, cold air intakes, even those that require a tune do very little for providing real performance gains over the stock airbox. As it's the remapping of the stock tune which provides the actual HP/TQ gains and not by adding some large diameter air intake system. Also take into consideration the stock 3v airbox is fully capable of providing enough airflow to support up to 500rwhp. Therefore don't be fooled by those air intake manufacturers who claim their large air intake systems provide up to 35 additional HP on a stock 3v engine, as they're marketing hype claims are full of nothing but bullshit. The reason, the intake and exhaust ports of the stock 3v motor are only capable of taking in the amount of airflow for which they were designed by the factory. Unless upgrading to larger heads, throttle body, cams, forced induction and so on that actually require and can make real usage from larger amounts of airflow, anything beyond what the stock 3v engine is designed for and can realistically support, is just plain useless and considered as overkill. That being said, you would be far better off just sticking with your stock airbox by putting in a high-flow filter and finding a reputable tuning specialist to provide you with a performance tune for your stock airbox!Any of you guys can recommend the best air intake system. Im contemplating a Roush but fancy a stainless system like BAA too ??
I already posted my results. Stock airbox wins as far as colder IATs and has less of a heatsoak effect.You guys make valid points on the actual air flow. What about IAT's? Any improvements there with after market air intakes?
Agreed! As your exactly 100% spot on. Also good to know that some of us actually "get it"So let me enlighten you guys on "tune required" CAIs. There is absolutely NO HP increase by installing and getting a tune for ypu specific CAI. Here is why:
With my JLT, i got the MAF transfer from them, and that is all that is needed to be changed in the tune. This results in ZERO power increase, but you may gain a few hundred usable RPMs at redline IF and only IF the stock airbox is restrictive at high air volume.
Now, if the tuner makes some additional changes to the tune while adding the new MAF transfer, then you can see some gains in HP. But you could also make those additional changes in the tune, keeping the stock air intake and get those gains.
The only reason to go to a tune required CAI or larger mass air sensor is IF you are PEGGING your stock setup because your ported heads with cams and long tubes now move way more air than stock.
