K_Brogoitti
Columbia Basin
Go slower than 100 mph lol
Sent from my phone, spelling mistakes brought to you courtesy of tapatalk.
LOL that ain't no fun tho. :beerdrink:
But what do I need to do or replace? I installed 4.10's recently and Strange Adjustables. But that's as much as I've done to the rear. And it didn't do this before
Sent from my XT1080 using Tapatalk
skwerl
tree hugger
central Florida
Yes it did, but you were insulated from it. Now you have a more direct connection to the differential and it telescopes everything straight into the passenger cabin.
K_Brogoitti
Columbia Basin
So what you're saying there is no way around the issue? How about adjusting pinion angle? Balancing the driveshaft? New bearings in the diff?
lethe
V4g!n@ #er
Everett, Wa
Have you checked pinion angle?
AnotherS197GT
Serial Valve Dropper
USA
Put the car on ramps to check the pinion angle or take it somewhere with a drive on lift. You can also try clocking the driveshaft (if you have a one piece) to see if that gets rid of the vibe.
Not yet, I will do that tomorrow morning. If I find an issue with Pinion Angle is there a way to tweak it without an adjustable UCA? How would you load the suspension in the rear to properly check?
You can adjust with adjustable lowers. I'd recommend getting an adjustable upper though. 1 adjustment point is easier than 2.
Lansing,MI
Plowed the driveway
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
Started it up, got it off the stands and drove it around the block for the first time in a month! Have to have the torque converter pulled to reflash from a 2C to a 5C for the NA CJ intake setup.
bradleyem
Columbus, OH
Been getting random ABS light and Check Traction Control messages. So either I have something going on with the ABS (sensor going bad) or its time for another fucking alternator :-(
Sent from my DROID RAZR HD using Tapatalk
