So finally broke down and got a wot box, thanks Tom!
I have read through the threads and the setups instructions and now I have a question/idea if you will.
So normaly from a roll with a turbo you can brake boost. Lightly press the the brake with your left foot as you roll into the gas to maintain your speed, build boost and then let off the brake and go wot under boost.
With a wot box can you "clutch boost"? lol Im guessing you could use either the no lift shift feature or 2-step feature to do this from a roll.
No lift shift feature set to auto: driving 55-60mph in 5th gear go wot then immediately push the clutch in, this will activate the no lift shit and start cutting timing. Instead of immediately shifting and letting out the clutch, downshift to the gear you want, lets just say 3rd gear. This hole time while you are holding down the gas, and the wot box is cutting timing you will be dumping fuel and building boost. Once you build the desired boost or your ready to go just let out the clutch. This can all be done in 2-3 seconds so you will be coasting maintaining your speed and waiting for those 3 honks
This would be even better than just downshifting with a turbo as you will actually be already in boost after the downshift.
Would this work? Anyone with a turbo/wot box tried it?
This could also work for the 2 step feature, say in 4th gear on the highway, going 55-60, let off the gas and push the clutch in to coast/idle, go wot to activate the 2 step, start building boost then clutch out to go.
What yall think? Am I
or would this work?
or would this work?
