WOTBOX + 5 speed users....
fdjizm
Drag Queen
NY/NJ
Nice I have to get a wotbox now, shit!
IMO the main benefit of the WOT box is that it doesn't upset the car. I can pretty much shift gears just as fast without it, but not without causing the nose to dive and come back up or break the tires loose which slows the car down.
That's where I am losing time, now matter how fast I shift the nose dips.
probably because I take my foot completely off the gas obvsiously but wotbox would help with that wouldn't it :)
joedls
Dragracer wannabe
Lake Forest, CA
Not if you take your foot off the gas pedal.
fdjizm
Drag Queen
NY/NJ
Well yes that's what the box is supposed to help with, keeping my foot in lol
I'm not good with powershifting anything but 3rd gear.
TheKurgan
Florida Keys
If you take your foot off the gas it won't even work like Joel said.
Powershifting does the same thing but the thing with that is you can still break the tires loose/hit the rev limiter/harder to get the synchros to line up. It's also much harder on the transmission. The WOT box eliminates all those things.
fdjizm
Drag Queen
NY/NJ
Just bought one, did some research found videos read manuals this is will be a great addition to any car, I got the 2-step + no lift shift version I've always been good with soldering. should be easy to install. :clap:
luillo
Fort Walton Beach, Florida
Thanks man, :clap:
hey man i am one of those guys that sucks very bad at electrical problems and anything related with electricity but i am also very detailed as possible on my work, so i got the WOT BOX and read the instructions for 1 or 2 days then installed step by step and it work perfect. The only problem i ran into was the software and it wasn't really a problem it was only confusion on how to use it. the instruction in their web site are very easy.
If you have any questions let me know and i might have some pictures too.
blacknlte
Odessa, Tx
Should have checked with Tom or AJ with Amped cause they had a great deal on them!
fdjizm
Drag Queen
NY/NJ
I got overexcited lol
Is there any issues with the cats when using one of these?
Only if you hold the 2-step for too long guess it's bad for the cats, dumping fuel etc... I am figuring that is at least after 5 seconds though, who holds a 2 step that long? (besides ricers) lol
Branman
Delaware
Yes you will destroy them if you use the 2-step often and for long periods of time. I mainly use the no lift shift portion right now as Im still getting used to launching the car at the track. Once I get a good RPM launch at the track I will give the 2-step a try.
TheKurgan
Florida Keys
Just FYI If you have nitrous you don't want to spray through the shift. It will sound like a canon going off. Wait until you get outside your window when it's not spraying.
And yeah I wouldn't use the 2step if you have cats or restrictive mufflers.
fdjizm
Drag Queen
NY/NJ
ok, I need help, i'm done with all the wiring except for the pair of red and black wires, it says to cut (two) wires on D5 of the bussed connector I am pretty sure it's the two wires on the 5th pin but on a pin one down and to the left there is another pair of red wires. so which one is it?
I am currently staring at whats under the green cover. anyone? I think it' would be the 5th pin logically but then u have a clone of those two almost behind it!? bugging me out.
luillo
when you take the green cover like in the instructions shows the pair of red are the ones like in the center of the cover close to the screw that hold down the plug. they come from the wire loom that comes from the engine and splice into the plug.
fdjizm
Drag Queen
NY/NJ
Ok the ones nearest the center screw? gotcha. the other two pair of red wires are near the edge, confused me for a sec. thanks bro
fdjizm
Drag Queen
NY/NJ
Got it working!, took it out for a spin my god how easy it is to shift with my foot on the floor @ 6k rpm, love me some assisted power shifting w00t!, 2 step works flawless also. I highly reccomend this device!
I left it on auto and it goes just as fast or as slow as I shift.
fdjizm
Drag Queen
NY/NJ
We need video!!!!
I will see if I can grab some vids tomorrow :)
Anybody got any catalytic converter horror stories? I am going to go very light on the 2-step only for track use till I get an o/r x pipe.
But I assume damage comes from over-use like sitting there for 3 or more seconds on the two step for like 10 passes or something am I right?
luillo
i am glad you got it is nice right???? i will have to look on what you said about auto. I never pay attention to that and it might help me better.
I have no bad experience so far except that i set it up at 2500 rpm at the track and use it for like 5 seconds because i was nervous and when i took off the car almost stop and ran very bad until it cleared the gas. I did it because i dont have good tires just Nitto 555r and they dont work.
other than that is cool...
