bigray327
Mine says 6923. That's not a good sign. Looks like it's the one for a cabled TOB. Somebody's gonna die.6912 will not work with factory flywheel must have Mcleod wheel , The 6913 will work with the stock flywheel.
I ordered from AMP under their group buy. IIRC I got the flywheel from Lethal though.
The setup on my 3650 was different. More different than just having 10 spline hubs although McLeod said they could rehub the clutches and I could of used it on the 6060.
The 3650 had a gold ring too. Edit: I see it's a 6912 also. I used this one with a Fidanza steel flywheel.
Another edit: Just did a search for 6913 mcleod. Here is what jegs says the different versions fit. http://www.jegs.com/webapp/wcs/stor...reId=10001&catalogId=10002&N=4294965982&Nty=0
Jeremy where did you order from?
Was this the number on yours? Is there any chance your shop took apart the parts that are shimmed by McLeod? Specifically the floater ring.
Summit shows that part# fits pushrod fords and chevys. Is there a # after the 6923? Like 6923-07 or 03,04 or C?
I pulled my RST clutch out this week and put in a Excedy mach 600 in. CURED all my shifting/grinding problems. Not sure what's going on with Mcleod lately but I'm not impressed. Wasted lots of time and money on that POS. Anybody need a Mcleod boat anchor?
From the Going Around In Circles Department:
I talked to McLeod this morning, and it turns out the part numbers are not my issue. The 6918 kit is just a packaged 6923-0x + flywheel, which is what I already have.
This merry-go-round sucks.
Next, I'm going to throw a 1/8" shim behind the slave, and if that doesn't work, I'm either going to replace the PP and floater or put in an Exedy Mach 600, whichever is cheaper.
I have a 26 spline TR6060 and their flywheel, so according to McLeod, I need the 6923-07 or the 6918 (which is just a 6923-07 bundled with their steel flywheel, according to McLeod).No wonder you are having problems, McLeod lists a 6932 for your car. The 6923 is listed for a small diameter flywheel.
http://www.mcleodracing.com/products/RXT+Twin+Disc.mcl
Edit:
A little more from the McLeod website pertaining to RST: 6912 is for a large flywheel (used by our motors) 6913 is used with a small diameter flywheel.
http://www.mcleodracing.com/products/RST+Twin+Disc.mcl
It is my understanding that it only makes a difference if you use the factory flywheel, If you use the Mcleods FW either PP will work. But i would prefure to use the 32 or 12.
Thanks Bruce. I'm just telling you what McLeod told me. My bottom line is this: if the TOB shim doesn't work with what I have, I'm getting an Exedy Mach 600.
when i measured my 3650 and the tr6060......ht einside bell housing/input shaft is 1/2 shorter on the tr6060.....making the TOB sit 1/2 closer on a tr6060....
Thats odd, my input shaft measurment was the same on my 09 3650, and 09 6060.
