Frpp cams
notastockdohc
Thinking about getting a set or mother thinkers idk. I know hp gain is okay, what I am after how hard would they be to instal by myself.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Definitley go with the mother thinkers!!!!! Those are mean as a snake!!!
LOL!!!:lol:
SteveP
Modular Specialist
Boynton Beach, FL
Have you given thought to our Stage 1s? You will get the same awesome sound and gain some good power with them.
You know what they say, if it's not one thing it's your mother.
Cams are pretty easy by themselves. There are plenty of writeups on this site.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Hotrods FTW!!!!!!! BAMA tune, excellent drivability, no loss in low end tq, and AWESOME LOPEAGE!!!!!!!
HEMI LOL
The Feast and The Famine
Fircrest, WA
I need to have someone install mine or help me install mine. I don't have the tools and im frankly kinda scared to do it.
notastockdohc
Same here bro I can rebuild a 5.0 302 pushrod motor easy, but theses modular motors are a different animal. Anyone know someone in ky that can do these.
StangPower05
"Pony Up"
NY
FRPP doesnt make Mutha "Thumpers", COMP does. FRPP makes Hot Rod Cams. IMO, you should go with the FRPP cams. Their sound is unbeatable..
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
No special tools required for NSR cams, very basic hand tools and a piece of garden hose is all you need.
There are a bunch of threads/write ups on here about the cam swap and once of them links you to the step by step process. Should take you 3 hours from start to finish and that's with taking your time and double checking everything. Another set of hands helps if you have friends that enjoy working on cars.
You WILL need a tune/handheld tuner if you don't have one already, choose them from one of the vendors...BBR, AM, Torq, etc.
notastockdohc
I was trying to decide between frpp hot rod cams and comp mother thumpers. I have a sct2 with bbr 93 tune now, if cams go it I will go back with bbr for updated tune. So this swap is fairly easy? 2 cam bolts and wedge tool.
Greg Hazlett
Official Vendor
Chesapeake, VA
2 cam bolts and you don't need the wedge tool; I have done 4-5 swaps without it and had no issues.
BBR is a great choice for the update.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
HOTRODS FTW!!!!!!!!
Installed them myself. No tools needed. Your back will be DESTROYED though from bending over. I looked like Quasimodo for 3 weeks!!!!
notastockdohc
Damn your car sounds good, would I need valve spring or just get the cams a the two bolts and go at it? How do you keep the car in proper timing?
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Take out the old cams..........install the new Hotrods with 2 new cam bolts. Easy as walking and chewing gum.
You do have to wedge the chain to keep it from moving. I used a clean garden hose cut ~3ft long and wedged it to keep the chain from moving.
http://mustangforums.com/forum/gt-s197-general-discussion/475980-hot-rod-cam-installation-guide.html
All the info you need and then some. If you are serious about doing them yourself, I can give you my number and walk you through if you have a minimal amount of mechanical abilities.
Proper timing? BAMA tunes FTW!! Chris Rose and the guys at AM meet and exceed all my tuning needs.
