From the sounds of things, based on Kelly @ BMR and others, post #2 is incorrect. Please disregard this post.
I guess I can go back and readjust mine correctly now
Does it vibrate? If not leave it alone.
You want to make the UCA shorter to move the pinion flange towardsKelly,
Can you post a picture of what you are talking about? I am so confused at this point plus I am a visual learner. What I am gathering from your posts is that I want to start with the trans pointing down and the pinion flange pointing up at the same angle (positive and negative are irrelavant at this point). Once that is acheived, I want to make the pinion flange go towards the ground 1.5 degrees from the previously measured angle which would be by making your UCA longer. Is that correct? Also, I looked at the directions Coast sent with thier driveshaft and they say to set the pionion angle to the same as the trans while at ride height and that is it (they claim the transmission flange from the factory is 2.7 degrees down).
How did you elevate the car like that? Drive up on the ramps on the rear tires and jack up the front?This morning I raised the vehicle, supported by the tires and level, and readjusted the pinion angle. The pinion flange angle is now 1.7* lower than the transmission output flange angle.
I never drive up on ramps. I raise the vehicle with a floor jack and then only use the ramps to support the stationary weight of the vehicle.
