Coyote HO Block Build
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
Looking good. What did you do with the old motor?
once i'm sure everything is rocking with this one, i will probably sell it.
we just freshened it up in august. new block, new bearings
konablue11gt
Evansville IN
If you dont have plans for your shortblock i may be very interested in talking to you about this. PM me if its becomes available. Id be interested in this along with more boost and another run on the dyno with you and Ken.
beefcake
Official Vendor
Bethel, Ohio
getting there....
brian should be done degreeing the cams in tonight, then should be smooth sailing.
Engine is already hooked back up to the trans, and on the cradle.
The ID 2000's fit much nicer in the new intake than they did in the boss.
Hardcore
getting there....
Sweet setup!
Do you guys normally work on an open engine, directly underneath the car like that? :)
cyclerick
Will MMR be doing a run of those manifolds? Is there much advantage to GTs with stock manifold to run one of those custom MMR manifolds or would the cost be prohibitive versus the benefit along with the need to also do rods, pistons etc?
