Car will not make boost. Need some help
CPRsm
Imposible! It passed the same inspection mine did!
Glad you found the issue.
inspector probably doesn't speak engrish. But don't notify anyone about it. They will probably kill one of his family members. Wait, they don't care lol
CPRsm
Did you measure to make sure the loss was at the core itself and nothing else making that worse? Or did you get a larger one?
Sprayer84
Omaha, Nebraska
I don't know what else it could have been. With it deleted there was zero loss. Also, it had a hole in it either way.
weather man
Persistence Is A Bitch
MN
Could powdercoating have heated it enough to damage the internal structure somehow? Such a strange failure.
CPRsm
No not at all. The cooler isn't mechanical. Nothing really to fail per say. Powder coat couldn't do it. Cooking the powder coat at 400 vs melting point over 1000 deg. Unless they sprayed the ever loving shit out of the inside some how
RocketcarX
95% of my weight is fuel
Colorado
So it was clogged? Is the take away from this that before when you were making "good" power you were pushing 20+ pounds of boost out of the compressor and only seeing 9 or 10 at the intake (which would mean it you read a spike in boost when the BC was installed wrong you may have been pushing 30 lbs of boost)? I would assume the new intercooler will fail again if it's the same style. the heat from that much pressure restriction would surely damage it in some way. Is it rated for 20+ lbs of boost? Is what your doing now a real fix or a band-aid sorta return to what "worked" originally? Sorry to ask so many questions, I just got a little confused reading thru this thread.
