What seats are you running?
frank s
at Play
Paradise
OK, so this is better?
SoundGuyDave
This Space For Rent
Mark, make sure you get a piece of safety-wire or a tiny cotter pin in the lock hole of the snap-link. At least in our region, NASA tech was cracking down on that in post-race safety inspections as well as at the annual tech...
csamsh
OKC
good idea, thanks for the tip!
jayh007
Northern New Jersey
I was looking to put a set of racing seats in my car with either 4 or 6 pt Harness. My car is not a DD but I would like to use it on the weekends every so often. I was told by a reputable source that only the standard 3 point harness is street legal and you could be ticketed for having a 6 pt harness. That could be a problem in my area because I've come across number of police run seat belt check points. Has anyone encountered any problems in this area.
csamsh
OKC
You are mostly correct. Schroth makes a harness that is street legal, as it has the red "press" button to release it.
However- you wouldn't want to use a harness to drive on the street anyway. When it's tightened down, you can't do things like look over your shoulder or reach for anything. Retain your stock belt and use it on the street, and just put the harness on when you go to the track
sheizasosay
Alive
Anybody know what air bag bridge resistors I need? I have an 06 mustang gt.
o2sys
Not sure about 05-06 but 07+ need 2-2.2 ohms....
Sent from my HTC One using Tapatalk
sheizasosay
Alive
Thanks o2sys. I need to find out about the 06. Make sure I don't get the wrong one and deploy an airbag or something stupid.
sheizasosay
Alive
Seats arrived today. They are the Sparco Fighters. Gotta say, they look great, are very light and miraculously fit perfect.ImageUploadedByTapatalk1388091447.889786.jpgImageUploadedByTapatalk1388091473.749941.jpgImageUploadedByTapatalk1388091490.488328.jpg
Those zoomed in spots are on the sticky material. Camera sucks, but they are grippy.
I'm pretty well pleased. I got the airbag simulators on the way. I went with the $55 ones because they have the correct 2 ohm resistor already in it as opposed to buying the ford part that has a 10ohm resistor that would need to be changed. Just waiting on my seat brackets to get here. 2 sliding brackets and 2 seat bases ($350), 2 seats ($1140) and the 2 seat simulators($110) total $1600. Not bad.
Thanks for your help Gmitch.
Gray Ghost GT
Road Racing Fanatic!
Madison, AL
....Schroth makes a harness that is street legal, as it has the red "press" button to release it.
.....Retain your stock belt and use it on the street, and just put the harness on when you go to the track
+1
jayh007, Schroth makes an excellent harness and the red "button" version is really nice. Since my Mustang is a 'daily driver' that spends some time on the road courses using stock seats, I had a set of the Schroth Profi II ASM FE (4 point). However, if you're going with an aftermarket race seat, I highly recommend going with the 6 point version. There is also a version if you plan to wear a HANS device.
Mike K
WANNA BE FAST
Richfield, MN
They sent those to you? Fucker put the wrong address on them.
They look good. I'm still trying to find a good deal on some sparco evo seats.
jayh007
Northern New Jersey
Seats arrived today. They are the Sparco Fighters. Gotta say, they look great, are very light and miraculously fit perfect.View attachment 46255View attachment 46256View attachment 46257
Sounds like a good deal. Post a review when you get them installed I am curious to see how it goes. Also who did you purchase the seats from?
sheizasosay
Alive
I'm waiting on Sparco bottom mount bolts and the airbag simulators. I already have the passenger seat out of the car. As soon as they get here I will finish it up.
Passenger non-power, leather seat weighs 50lbs. So there is a 20lb savings over the new seat and bracket. Interested to see the driver side weight as it is a power leather seat.
I purchased the Wedge Seat brackets with sliders from http://wedgebrackets.com/master-bracket-guide/
Seats were from Amazon.
jayh007
Northern New Jersey
What bottom mount bolts did you have to order from Sparco?
