petersonb
UPDATE 1/17/14
Wow, it feels like it's been a crazy couple of days. I was really undecided on getting another block or trying to use the one I currently have. After going and spending the time with the block (and about 85 photos later), I had decided to give it a go -- how bad could it be, right?!
I had decided to document everything (hence, the 85 photos) and put a blip on someone's radar if they were to ever come across a RFXE-6015 block and try to look something up. There's really not much information available on this casting number.
So, I had decided to use this block, run it for about 20-30k miles, then tear it down and assess damage. I sent Manuel (Lito) an email, "[Hey, using this block..]" etc. Long story short, he says, "NOOO" to using a sleeveless block. To all of you reading this who know anything about motors, that's a no-brainer, I'm sure. To me, however, noob.
(Btw, shout out to Lito for saving my ass. <100 mi and I'd be right back to where I am now)
I decided to go with this other Teksid block, which was 4hr drive away, but had a casting number of RF-F2LE-6015-HE, which I have tracked down to a 1995 Mark VIII, which were all aluminum Teksids, from what I could tell. (Fast forward, I have the block; definitely aluminum)
I had the day off today, so I drove to Texas to get the "new block" (as I'm calling it). After getting it, I'M SO HAPPY I DECIDED TO GET THIS BLOCK INSTEAD OF THE RFXE. If you are reading this, considering using an RFXE block, please stop. Seriously.
Below are some photos of a few of the differences.
A list of a few of the discrepancies:
"New Block" has...
Sleeved cylinders
NO handwriting
Different (i.e. PROPER) format casting number (usually RF-_ _ _ _-6015-_ _)
Date code stamped in two places
NO numbers/letters on the studs (old block had "325" on one of them)
Now, pictures:
OLD BLOCK (Not sleeved cylinders):
NEW BLOCK (sleeved cylinders):
OLD BLOCK (handwriting):
NEW BLOCK (NO handwriting):
OLD BLOCK (Casting number, weird format):
NEW BLOCK (Casting number, common format):
OLD BLOCK (Date stamped ONLY here -- Front):
NEW BLOCK (Date stamped in two places -- Front and rear/top):
OLD BLOCK (Numbers on studs):
NEW BLOCK (NO numbers on studs):
I will try keep this thread to the build, but THIS LINK goes to the thread I've started to discuss the oddities of this RFXE block. It's weird, and no one so far has been able to tell me very much about it.
Also, the rust appeared to only be on the surface of the piston. A good bit of it came off quickly with just a rag and WD-40 while looking at it in the parking lot upon pickup. Should be good with a 0.020" over bore (it's standard bore right now).
I should have the rotating assembly back, balanced, mid next week, and will drop the block off Monday to get the cylinders bored and the main caps line bored to match the block.
Thanks for reading!
BP
"New Block" has...
Sleeved cylinders
NO handwriting
Now, pictures:
Thanks for reading!
BP
