http://www.svtperformance.com/forum...ew-build-for-heads-up-racing&highlight=blower
Something North of 1050 powerwise
Well it works, there is no doubt about that.
Looks like Gmitch has some homework to do and decide how far he wants to take this. I do like the Keep It Simple Method, and to retain the 3 link suspension while running a M/T 275 Pro seems like a path that no only works, but would be friendly to the wallet.
As far as the cost of the trans, the 4R100 would only be about $1K more expensive, but then you have OD, albeit at a higher weight. But if he wants to make this a "drag week" car, then the OD would be worth the extra weight.
And just think, I get to put a roadrace car together too (assuming I don't sell all my RR stuff and just rent track cars).Yes that is the one.
The tire I use is a 29.5X10.5WX15
IF I were to drive this on the street (like if I moved to Montana), I would use a 315/60/15 M/T DR. Both tires are pretty tall, which is why I mini tubbed the car. So I could run the tall tire yet avoid the 4X4 look, and have the tire go under the car vs the car sit on top of the tire.
Paul, the stance of your car is just so effing awesome man...
Gmitch, please make your car sit exactly like Pauls.
One thing you have to consider is: is there any rules on tire size in the classes you will be racing? The 275 tire is about the most popular tire right now in a variety of classes.
There is a very popular 8.50 index class. Out here in CA its B/Gas, or an 8.60 index class.
To the spectator, it "looks" like a heads up class as the cars get the green at the same time. But you can't run an 8.49, you have to run as close to an 8.50 without going over, like the price is right.
Yep, as in quicker than an 8.500
The advantage to this class is you can build whatever you want, weigh what you want, use whatever tire you want, just run as close to 8.50 as possible.
8.50 Index-1/4 mile all run up to 32 cars qualified field
1. .400 Pro tree heads up with a 7 second auto start
2. Minimum weight 2800 lbs
3. Deep staging permitted but auto start will be on at all times—courtesy staging advised
4. Full bodied street appearing cars only—no roadsters, altered or dragsters
5. Lettering allowed on windows only
6. No full round or square tube chassis
7. Stock style front suspension (bolt on aftermarket parts accepted)
8. Tran brake and two step allowed
9. Throttle stops/controllers, delay boxes/devices are Prohibited
10. Automatic shifters prohibited
11. Mufflers mandatory—turbos are considered mufflers
12. Car and driver must meet all NHRA and track safety rules
13. Gasoline or alcohol only (Nitro is prohibited)
14. Max tire size of 33 x 10.5w
15. NHRA Pro ladder
16. All entries must be driven under own power from shutdown to scales—towing everywhere else is permitted—this is appreciated but not mandatory.
Actually we also have rules 1,8,9,10. I like rule #4. Rule 12 is always assumed out here, as all of our tracks are NHRA.
There was a need for rule 13? Now who tried to run nitro for an 8.50 car?
Curious about the minimum weight, all though if you look at #4, I guess they would go hand in hand.
