05stroker
Never enough power guy!
I think I have an intake leak here and that is why I still have a bank to bank difference. I have ordered a set of these to help with the issue.
After having my JPC intake ceramic coated it was distorted a bit and when I bolted it down it seemed to seal. I used rtv and a paper gasket between the delete plates and the intake and rtv to seal the gasket to the delete plate on the bottom. I did not use anything on the seal between the delete plate gasket and the head though. I think this is where my leak is. Vacuum is lower then normal and I have a bank to bank difference of a full point on the A/F gauge. Anyhow this is where I am at for now. I will post up after I have the new gaskets here. I think I will need to port them same as the other parts.
http://www.ebay.com/itm/BRAND-NEW-FORD-OEM-RH-LH-INTAKE-MANIFOLD-GASKETS-4-6L-5-4L-/261468719319
