I found a lot of info on IC pumps at a Mercedes forum. There are a couple good threads and a flow chart comparing 18 pumps.
It seems that the GT500 pump (Pierburg CWA50) has a bigger version Pierburg CWA100.2 that seems popular with the Mecedes crowd. It sells for $375 and is the same pump Renntech (mercedes perf shop) uses for supercharger upgrades.
http://www.oemercedesbenzparts.com/...6?origin=pla&gclid=CLj0gd6N6csCFYY2gQodu-UHrw
Thread on pumps
http://mbworld.org/forums/w211-amg/411058-intercooler-pump-you-didn-t-know-about.html
More info on pumps, HE's and pump flow
http://mbworld.org/forums/m275-v12-...oolers-heat-exchangers-circulation-pumps.html
Here is a quote with a good summary.....
There are some long-established golden rules for installing (centrifugal) pumps, including:
• The pump inlet pressure should be as high as possible.
• Therefore the pump should be located at the lowest point in the system.
• Locate the pump after the radiator, to keep it as cool as possible.
• Mount the pump horizontally, to minimise bearing end loads.
• To avoid air locks, the outlet should be at the top of the pump, and must not point down.
• The pump's pressure/flow characteristics should be matched to the system resistance curve to achieve best performance.
• Don't run a pump into an excessively high or low resistance, or it will fail quickly.
• Keep air and contaminants out of the system.
• Finally - feed the pump from the BOTTOM of the radiator, to minimise air ingestion.
I also attached the pump flow chart.
I was just going to buy the GT500 pump for $275 from Tasca but maybe its worth the extra 100 and go with the bigger pump from Mercedes.
