Midlife Crises
Fairbanks, Alaska
Pulled the upper control arm and mount and moved the control arm from the top hole to the bottom on the mount then put it back together. Also set the pinion angle to 1.5* down from the transmission. Never played with the upper settings so I’ll see how this works out. Also had a Klunk in the front end that I had to find. Removed the Steeda upper strut mounts and put the stock ones back on and on a test drive there was no klunk. Now I just need dry, warm pavement again.
Jgt58
Finally got the pads I wanted. Glad I get work discount[emoji106]
Swapped in a new TB motor, had some issues since I can’t read, LOL, clockwise vs counter clockwise matters...... replaced the 7 YO battery, hoped to get it running for the first time in 10 months.... no joy, still P2104 DTC and failsafe mode
Gabe
Whippled Coyote
Any other codes present?
The little googling I just did tells me that that code doesn't send to set by itself
GlassTop09
Farmington, NM
Nothing yet but this is coming soon...………very, very soon……………….
Box on the left is Ford Performance part# M-8C607-MSVT 05-14 GT Cooling Fan Upgrade, top box is the 07-10 GT Mishimoto HP Radiator Hose kit (in black) & bottom box is the Mishimoto 3-Row HP Aluminum Radiator for 05-14 GT.
Gabe
Whippled Coyote
Drove it, trying to get it to go OBD ready.
Had to load another tune but it finally went ready. Now I need to get an appointment for a state inspection.
The first time it went failsafe there was. Once I replaced the motor it’s just the 2104. This is the thrid time I’ve had the issue with just the one code
Christenn23
I'm envious. My heat exchanger is awful, once the blower gets heat soaked it feels like I'm N/A.
Jgt58
We have absolutely no emissions laws here in Knoxville TN. [emoji106]
Gabe
Whippled Coyote
Pulled out the wife's Shelby, ran it up to full temp, reset the tire pressures and torqued the lug nuts.
Still need to put the new McLeod RXT in it, but my good friend that's done a bunch is looking to help us get it done. Maybe as early as tomorrow. Here's hoping.
Don't take drives to triple digits with the plate folded under.... band things happen.... don't ask how I know.
