Calling all boosted STOCK ENGINE 3v's
Jbarker83
I wanted peoples stock engine boosted 3v info seeing what everyone is using
type of forced induction
how much whp/tq
how much boost
what mods
at/mt
result still running or blown motor
thanks!
LarryJM
Resident Fuktard
Five lbs did the trick for the time. It was simple and easy to install.
MrAwesome987
Upstate SC
  • M122 Supercharger with DOB manifold
  • Dyno'd at 460 WHP/ 440 TQ
  • 10-11lbs
  • Blower, Detroit Rocker Blower cams, long tubes
  • MT
  • Installed all this at 140k miles, still going strong at 157k. It's had plenty of WOT pulls and 1st and 2nd gear burnouts at 6500 rpm.
Edit: I forgot, I installed an Exedy Mach 500 clutch after the stock one gave up around 147k.
Whipple 3 1/8" pulley
first tune dynoed 465/505
5 years at 460/485 ran mid 11's @ 120 mph
currently 460/465 guesstimate
11.5 psi
Installed blower at 50K miles, current mileage 118K and I drive her like she's stolen
mods are listed in sig
3rd automatic transmission
Currently runs like a champ
And your gonna get moved cause this is definitely not tech
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
Powerhouse Turbo Kit Precision 6776 Turbocharger
60lb injectors/Ford Racing GT500 pump kit/8-9lbs of boost
488hp/442 ft-lbs on a dynojet
4 years, 20,000 km
Charge motion delete plugs/Roush UD pulleys/Exedy Mach 500 clutch
Broke the spider gears in the stock diff at the track. Upgraded the oil return line from -8AN to -10 AN as it would smoke when it was cold out. Did have to adjust couplers and clamps from time to time.
Best ET: 11.42@121mph
Motor was pulled out and built prior to any failure. The Built motor melted a piston.
LarryJM
Resident Fuktard
He asked for 3v data.
Hey the Paxton goes back a long way. At first used by Studebaker and then the company stayed in business with Nuclear Subs. Once Ford came up with Fuel Injection, Paxton reissued a kit just for the Mustang. The Paxtons are sort of related to the Studebakers. I know you hate useless information and I am sure you would make Thomas Edison and his friend Henry Ford very proud. Think of it as "What did you have to eat for dinner last week" kind of question and answer.
not a tech topic... moved, please review the tech posting rules
also this topic is beat to death on this site.
RED09GT
On slicks? For street tires, I was under the impression that the stock gears can handle far, far more power than you listed.
325/50-15 drag radials, and it happened on the dreaded dead hook.
I love the stability of the drag radials but I'm going back to a bias ply with my next tire-unless I smarten up and put an auto in it.
Laga
Chicago
Edelbrock E-Force 8-9 pounds boost installed at 46K miles about 4years ago. 56K miles now. Lito tune.
Detroit Rocker cams, Kooks LT headers and H-pipe, Borla Stingers exhaust. Converted to E85. 500RWHP/450 torque. 3.73 gears. Automatic with TCI 2800 stall converter and hardened input shaft. DSS 1 piece driveshaft. Wilwood brakes.
Jbarker83
11.5 psi
Jbarker83
im using a paxton intercooled making around 500whp tuner tells me its to much for a stock engine so curious what everyone else was pushing etc
DieHarder
M122 w/DOB manifold; '13 Heat Exchanger/pump; IAT's run from a low of ~80 to ~130 summer with a nominal of about 100. Depends on time of year. I've seen winter averages even lower when warm.
whp/tq - Est 450/430 - never had it dyno'd. Tuned by Lito.
Boost ~8 - 9lbs
Mods- stock engine/exhaust - lots of handling mods - upgraded struts/shocks/brakes/bracing/etc....set up as a well handling grand tourer vice drag/race.
AT
Installed at 130K; running great ever since.
RED09GT
The newest thought process is to limit torque to under 450 ft-lbs as the key to keeping the stock rods inside the block. Horsepower doesn't make that big of a difference.
Jbarker83
yeh i was thinking keeping it around 450 and limiting rpms to around 6300 or lower
