11 Second NA S197's
Matt D
S197 Pilot
Toronto,Canada
Well since im on a mission this year to go 11's with stock internals, I want to know what you guys have planned to get into the next level and make it to the 11 sec club lol
There was a huge thread months ago that turned into caos.
Anyway I hit the 12.36 @ 107 mark last time with a 1.64 sixty foot, only suspension in the back was upr lower race control arms
I am now going to
Buy a one piece alum drive shaft
62mm T-body
Put my bmr anti roll bar kit on
I have a stock plastic PORTED intake that im going to test :p
chad05gt
Lake Charles, La
Get to the track w/o breaking anything... :beerchug2:
Getting to State Capital this Sunday... preying for good (South Louisiana in Summer good ) weather:helpme:
chad05gt
Lake Charles, La
what rim and tire combo?
15" Jegs 10.5x27" M/T ET Streets, 15" Jegs skinnies up front w/ M/T's, first time w/ GT500 tb... hoping to get a tune w/ it just to be sure...
Just front sway bar, jack and spare removed @ 3550 w/ me in it (200lbs).
fixt
Matt D
S197 Pilot
Toronto,Canada
Just front sway bar, jack and spare removed @ 2550 w/ me in it (200lbs).
nice! You mean 3550 lol
15" rims are awesome, I was launching mine off a 6100 limiter and just dumping the clutch and it hooked really well. Once I do cams it will make power past 6500 so I would lanch it even higher lol
chad05gt
Lake Charles, La
I spin w/ dumping at 6K... have had my best luck holding 3000... flooring and dumping as it rises just before 5K...
I dont know why spin so much... set up or something isnt right... THAT's been my Everest this season :thud:
Matt D
S197 Pilot
Toronto,Canada
im running a 26 x11.5 x 15 used set of et streets lol.. thats whack it spins like that.. maybe track prep is junk. I assume your doing a burnout?
chad05gt
Lake Charles, La
yup; d specs full on rear (one round less dr side), front full soft, -3 pinion angle, relocation brackets moved this season to bottom... may be too much??
Ill try a few more things this weekend...
kleistang
Miami Florida
i hope to make a 11 sec pass this friday. hopefully i'll make it.
i have all the listed. in my sigh plus lt headers, gt500 t/b, k-member, and if upr decides to finally send me the swaybar delete.
i'll tune the car at the track on wenedsday but its and 1/8 mile.
Matt D
S197 Pilot
Toronto,Canada
I have the relocating brackets sitting in a box but I have mixed emotions about putting them on lol... I might try them but first I will put the anti roll bar on. What gear are you running? 4.10's?
chad05gt
Lake Charles, La
4.56's... I have steeda rear sway bar; the anti roll bar is awesome, I just dont want to sacrifice the handling in my daily driver...
Matt D
S197 Pilot
Toronto,Canada
you have 4.56's in a daily drive 5 speed gt lol!? dam I thought my 4.30's were bad
GERMANSHEPERD
Ohio
LOL ive hit a brick wall with 12-teens for now. My car is making more power and has almost gone 113 but my 60's have gone backwards and i guess stock 17" rims arent helping me either.
Matt D
S197 Pilot
Toronto,Canada
nice numbers sir, you are very close lol
US-1
Banned
The ShadowLands
Do you mean you have them full stiff or full soft? If they are full stiff then you are knocking the crap out of the tire. Try setting them in the middle of their adjustment. What air pressure are you using in the tires?
chad05gt
Lake Charles, La
Makes too much sense... I hope its something that easy (and stupid on my part).
Yes, full, nearly full firm... Ive tried from 20-8lbs... pullin' my friggin hair out w/ this...
What air pressure would you suggest with the middle setting?
Am I ok w/ full loose in front?
Matt: Thats 4.56's w/ 6 speed... not bad at all.
I go through traps at 6500 at top of 4th 1:1 w/ 27" tall tire between 112.5-114.5mph
Matt D
S197 Pilot
Toronto,Canada
some one just sent me this pic of my car...
I was like OMG that thing is leaving hard!:omfg:
I should change the springs next time I go... lol
marcspaz
~Resigned~
holy shit, you lift the tires and you WILL be dragn' the bumper... LOL
