So..... been driving the Mustang for the last three weeks and..... It's just great.... I just love seeing pedestrians obviously staring while I drive by hahaha
But.... the stupid Modul to seperate the brake and turn signals is acting up and now only works when the engine is not running.... replacement does the same so I'll have to find another way to do that.... I do wonder if theres somewhere buried in the SJB firmware a option to seperate them, because if I unplug it one curcuit has a error code for turns and the other for brake signals.....
Also still looking to get the other LEDs made for the sequentials......
Other than that I also did the spark plugs and coil boots. I had already bought the extractor set beforehand but.....
8/8 came out! There's probably way worse since mine only had 30k miles on them, but I still had to soak them with fuel system cleaner and work them back and forth.
Driver side was particuarly sketchy feeling since they didn't gradually loosen like the passenger ones but just suddenly became very loose after being very tight....
Also got to try out the fender cover I bought and 10/10.
Crosshatching and all Cylinders + Pistons looked great. Cleaned the gunk out of the sealing surfaces and holes.
Blasted all the crap and fuel system cleaner out of the combustion chambers with shop air.
Gooped the Plugs with Motorcraft™ High Temperature Nickel Anti-Seize Lubricant (as per TSB), cleaned and new boots on the coils. Unfortunatly one coil plug broke so it's currently zip tied on until I get the new connector.
Flood Mode started it to remove any left over fuel system cleaner and fired right up.
The new plugs and better fuel will definetly help with the carbon build up.
Other than that drove it over 900km on a weekend visiting a friend and a S650 plus a lambo on the autobahn made me burn a quarter tank just doing pulls and I didn't kill myself haha.
Once the lift is empty we'll do the trans oil, power steering fluid, brake fluid to DOT4 and coolant. Rear Gear Oil I will do after the underbody is cleaned and sealed so they don't mess up the Ford Racing Diff Cover I'll put on at the same time.
Also in the process of getting some interior aswell as non fitted options parts over. I wanna put in the factory Anti-Theft-System aswell as Ambient Lighting still.
I think that's all for now lol
