Going to see what the Saleen blower is really capable of...
MickeySaleen
Barricade
This thread is going to cover my build that will take place over the next two to three months. My plan is to buy everything in the list below over the course of the next two and half months, one mod at a time. I will start with the most expensive items to get them out of the way. In this thread, I would like input on what I might need to add or subtract from the list. The goal for the car is to be very streetable. I WILL be taking this car to the track when the build is done and will work on getting into the 10's. I really do not want to start taking this thing to the track consistently UNTIL I have a daily driver. Anyways, here is the mod list...any input is welcome!
- Livernois 298ci Stroker Shortblock
- Livernois Stage II Heads
- Comp Beehive High Load Valve Springs
- Steel Retainers
- ARP Head Stud Kit
- GT500 Oil Pump
- Livernois MLS Head Gaskets
- 63# Injectors
- BGG Performance 8-Rib Kit with 3.20" Supercharger Pulley
- Meziere Electric Water Pump
- BMR K-Member
- BMR A-Arms
- Spydershaft
I will continue to update what is purchased and what will be purchased next as time goes on...shooting for 560-570rwhp with the 3.20" pulley and dependent upon the tranny holding up, I may throw the 3.00" pulley on there and shoot for ~580rwhp. I already found a killer deal on the Livernois Stage II Heads which I ordered today! Next up, Livernois shortblock in a few weeks!
chad05gt
Lake Charles, La
transmission will be interesting on that first launch and hook!:naughty1:
Mick, you have a tru trac or locker already, right?:thumb:
Livernois Motorsports
Dearborn Heights, MI
Is your car an auto or manual? At that power level with an auto, it'll be easy to go 10's, but the trans may not be too happy. Our white car made quite a few 10-second passes with the stock auto though.
The rearend should live... The Shelby "GT800R" has tons of hard launches on a tire with the stock clutch, trans, and rearend and has been 9.90's at mid-140's.
Keep us updated with the build and thank you for running our products! :thumb:
-Rick
MickeySaleen
Barricade
I will not be taking the car to the track until there is a TR6060 in the car
1FastS197
Hickory MS
sounds like a nice build but if it is a 3650 trans, i think its only rated for like 360 ft lb... but i have seen 488 ft lb's on one and it is holding, minus one input shaft... we think it was damaged in the first place, the new one is holding fine...
ninja edit: we all posted at the same time... lol
chad05gt
Lake Charles, La
-Rick
Trust that you have a special 3650 and spicer... or maybe b/c track only car ;)
05mustang_TT_charged
Because Race Car!!
LSU Country
I think JDM has already found what a Saleen can do!!! As well as a ''stock'' 5R55S can handle also. I think it will take a lot of R&D to beat those guys times with a Saleen and probably impossible with a 5 or 6 speed manual.
Nice build though and looking forward to see the progress over the next couple months.
MickeySaleen
Barricade
I didnt see JDM put out numbers anywhere close to mine with the amount of boost my car is seeing and my current numbers are with stock heads...who knows, we'll see what happens..I know its not all about dyno numbers but it will be cool to see what this thing will hit...it dyno'd 488rwhp @6.5psi on a pretty "unhappy" dynojet. My buddies car with a JDM stage II kit put down 420rwhp on the same dyno, same conditions. The JDM II kits usually put down 440-460rwhp
There are guys with 600+rwhp running the stock 3650...but who cares, that is not an issue for me as I will be upgrading to a 6060
MickeySaleen
Barricade
I will never beat the track times those guys put down with a saleen blower, not even gonna try to hit 9's...plus their numbers are through an auto, I have a manual.
Because Race Car!!
LSU Country
True I think is was told there car put down 604 rwhp and ran a 9.7 at 140, it would be pretty cool to see a 650+ rwhp Saleen car running around. Good luck with your build and hope everything goes smooth for you.
navyman8903
- Steel Retainers
- ARP Head Stud Kit
- GT500 Oil Pump
- 63# Injectors
- BMR K-Member
- BMR A-Arms
- Spydershaft
Good luck mickey...I wanna see that bizo when she is done! and buy a sweet camera so I can see some vids!!!!!!! :beer:
SUHleen
Central Ohio
Mickey, I know this is off topic, but what did you change out your racecraft suspension to? I want to sit a little lower with the Saleen and I thought your setup was perfect...
silverstang07
Dibs on your stock longblock!!! Just drop it off at the house next time your at home. LOL. Good luck with the build. I need to get my shit together and get started on mine but you know how that goes. Let me know if you need any help, got ALOT more 3v experience under my belt since your cam install.
