My long awaited build... (I don't think 56k exist anymore) So lots of pics...
tmcolegr
It's All About the Build
Central, FL
Says "FordMoCo some numbers then FA"
So I guess FA is what you are looking for?
Yes!! Your engineering change level is "FA". Current production is "KA". That means there have been 5 revisions/changes/improvements made to the design of the phaser since yours were produced. Sure hope you don't have any issues down the road with yours. That is why I changed mine during my overhaul. Supposedly the newer phasers are more reliable.
tmcolegr
Central, FL
Yup, no such luck there... 0 for 8. Torque wrench set at 25 and only popped a couple times. Then I went back and fourth as instructed and still broke every single one... :/
Here are 4, the other 4 are stuck in the heads separated and won't move. So I will make a couple calls tomorrow for some help... On to something else.
Holy shit!! I don't think I know of anyone that has broken all 8. How many miles are on your vehicle? Be sure to use the nickel anti seize when you reinstall the new ones.
Boozshey
Tampa
Well I am not messing under the hood the rest of today. I am going to start some of the other things now. I need to figure out the cost of getting these plugs removed now... I guess at 64k miles it was bound to happen.
My mother always told me to be the best at something, but I don't think this is what she meant... haha
Redfire_WNL
THE BEAST UNLEASHED!
TAMPA, FL
Damn you broke all of them lol. What are you doing now the gauges on the side or the ones on the dash?
Chris06GT
Dragging LS A..
Alabama
When taking plugs out, I always pull the coil's, spray some bolt/nut loosener spray down around the plugs, let it sit for about 20-30 minutes, spray again, and start working them out.....haven't had one break yet....(knock on wood).....
Dude, you are working your ass off....LOL....Which is what I need to be doing...
tmcolegr
Central, FL
+1
I have had to let a few with very high mileage sit overnight after spraying
Redfire_WNL
TAMPA, FL
Oh, i hope that goes well i mean it shouldnt be that hard. Except that you have to pull everything off to do that.
dysan
Dis-Member
Williamstown, N.J.
That sucks about the plugs. I brought my car to a shop the first time to get my plugs changed around 70k miles. 5 out of the 8 broke off on them. Now I just take them out, put some anti-seize and put them back in about every 5k miles.
Boozshey
Tampa
+1
I did one better... I sprayed the plugs before I started the cam install. Turned them a little bit and then let them soak over night even.
It's just time consuming, but I have extra switches.
Boozshey
Tampa
Ordered the spark plug tool... Put that on hold for a while.
Gotta repair the Aeromotive fuel rails and then starting the 8-rib kit...
Boozshey
Tampa
UPDATE:
Got the rest of the broken spark plugs out... Managed to get all 3 types of breaks. I know I am awesome but man, this awesome?
Also plugged the un-needed hole in the fuel rails.
Started some of the led changes...
Got all pulleys off but the Power steering and Crank... Gonna have to find a more powerful impact wrench for the crank and a different puller for the power steering pump.
Broken Spark Plugs:
Fixed fuel rails:
LED Change:
Pulleys ready to go on:
Old Pulleys waiting to come off:
Fuck this bolt:
Idler pulley:
A/C Pulley:
Tension Arm:
Water Pump Pulley:
This appears to be 10% bigger. The old one fits inside this one.
tmcolegr
Central, FL
do you need the proper tool to remove the alternator pulley?
If so just let me know.......
Boozshey
Tampa
Thanks...
UPS just dropped off the spark plug tool.
Finished all the LED's...
Still trying to locate a strong impact wrench!!!
Company will be in town so the project is on hold for a week.
Matt D
S197 Pilot
Toronto,Canada
awwwwwwwwwwww yeeeee
I love build threads! lol
This car will be a whole new beast when you take it out for the first time
Mr.CuBaN
Miami, FL
did you warm the car up b4 takeing the spark plug off.. that help alot i took mine of realy slowly
