JeremyH
3V Fuel Guru
Vortech procedure I used.
3. OIL DRAIN ASSEMBLY INSTALLATION [FONT=Arial,Arial][FONT=Arial,Arial](Engine oil-fed kits only. Applications with V-3 superchargers skip ahead to step 4.)
[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]A. [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]To provide an oil drain for the supercharger, it is necessary to make a hole in the oil pan. It is best to [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]punch [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]the hole rather than to drill it.
[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]B. [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Remove paint from the area around the hole.
[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]C. [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Mark the oil pan 5/8" down from the oil pan mounting rail on the driver’s side of the engine. Measure forward 3/4" from the first bolt on the side of the oil pan. (See [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Fig. 3-a[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial].)
[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]D. [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Use a small center punch to perforate the pan and expand the hole. Switch to a larger diameter punch and expand the hole further to approximately Ø9/16". Most punches are made from hexagon material and may be placed in a socket with an extension to make this procedure easier.
[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]E. [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Tap the hole with a 3/8"NPT tap approximately 1/4" deep. Pack the flutes of the tap with heavy grease to hold chips. Use a small magnet to check for any stray chips.
[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]F. [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Thoroughly clean the threaded area. Apply a small amount of silicone sealer or teflon paste to the new threads. Apply more sealer to the 3/8"NPT hose fitting and secure in the hole. Make sure a seal is formed all around the fitting. (See [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Fig. 3-b[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial].)
[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]G. [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Drain the engine oil and change the filter.
Fig. 3-b
[/FONT][/FONT]
5/8"
3/4"
Fig. 3-a
NOTE: This method of rolling over the lip of the hole and tapping it works very well if carefully done and should cause no problems.3/4"
Fig. 3-a
Fig. 3-b
[/FONT][/FONT]
