12.3 with minimal mods!!!
midlife
your 4.10 rear
a few questions if you do not mind:
i assume you needed to shift into 5th for the quarter correct?
is your et that much quicker than with say the 3.55 rear end?
lastly, what was the price of your rear end swap ?
thanks
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
thanks
gears are like $150, install will depend on what shop you have do it. Go with someone that knows how to set up a gear. Don't go to the cheapest
midlife
WOW, only $150 for brand new gears ?
coming from a bmw, that price sounds incredible.
lastly:
1/ i assume you needed to shift into 5th for the quarter correct?
2/ do you think your et that much quicker with 4.10 gears than with say the 3.55 rear end?
antonio1988
Redline: 8600rpm
Miami, FL
lastly:
He's automatic homie and gears are a must if you want to get those et's
GrnBullitt08
Dale Jr
Northwest Indiana
lastly:
Yeah the price of gears isn't all that bad. You'll need the install kit as well and do what beefcake said and invest the majority of the needed coin having the right shop do it or else you'll be out alot more than that $150 on gears.
antonio1988
Redline: 8600rpm
Miami, FL
QFT
midlife
BMR Sway Bar relocate!!!!!! :beer:
excuse the nob question:
what exactly does a rear (?) sway bar re locate do for the quarter mile?
and how does it affect normal road handling in the twisties?
thanks
PNR Welding
Hammonton, NJ
thanks
The only thing the rear sway bar relocate does is allow you to put a 15 wheel on the back.
