Matt D
S197 Pilot
Just got home about 15 mins ago. I woke up a bit late today and kinda started out on the wrong foot
Grabbed my coffee, Got to the shop just under 10am.
Alright first thing I did was unbolt the plate off the engine stand, and put the ground strap on the back of the head.
Then I grabbed a -8 45 fitting and my -8 hose and put it on (this is the main forward fuel line from the pump) Then I just left it on the bench lol.... ( The main key is to keep doing something... even if jumping around as long as things are getting done im happy)
Stock 3 V flywheel on left , new 5.0 flywheel on right. Look identical, just balenced differn't and the 5.0 has more holes
I havn't taken a close look at the back of them otor because of the engine stand but I just relized the crank trigger is in the back now. Pretty trick stuff from ford.
Bolted the flywheel on
Clucth bolted in
Shot from underneath of the header fitment
So then I go to walk to the bathroom and see my flexplate on the floor
Yes I forgot to put on the dam flex plate -_-
Removed everything again...
Bam! put that shit on (while cussing up a storm)
Ok put loctite back on all the bolts and put it all back together
After cleaning the trans tunnel a bit... The trans went back in (just like before the top two bolt's on the bellhousing is alot easier reach from inside the engine bay) Bolted the Drive shaft loop back up too. (no issues on anything)
Grabbed the starter , cleaned it and bolted it back up (no problem) Just had to take the studded motor mount bolt off to fit it in. Then put it back. Headers fitment really shines when everything goes in smooth.
Grabbed my coffee, Got to the shop just under 10am.Alright first thing I did was unbolt the plate off the engine stand, and put the ground strap on the back of the head.
Clucth bolted in
