Young Punk Build Volume IV - The game needs change & I'm the mother *@#%en cashier
Matt D
S197 Pilot
Toronto,Canada
Just got home about 15 mins ago. I woke up a bit late today and kinda started out on the wrong foot :tdown: Grabbed my coffee, Got to the shop just under 10am.
Alright first thing I did was unbolt the plate off the engine stand, and put the ground strap on the back of the head.
Then I grabbed a -8 45 fitting and my -8 hose and put it on (this is the main forward fuel line from the pump) Then I just left it on the bench lol.... ( The main key is to keep doing something... even if jumping around as long as things are getting done im happy)
Stock 3 V flywheel on left , new 5.0 flywheel on right. Look identical, just balenced differn't and the 5.0 has more holes
I havn't taken a close look at the back of them otor because of the engine stand but I just relized the crank trigger is in the back now. Pretty trick stuff from ford.
:roflmao:
Bolted the flywheel on
Clucth bolted in
Shot from underneath of the header fitment :p
So then I go to walk to the bathroom and see my flexplate on the floor :mad2: Yes I forgot to put on the dam flex plate -_- :ugh1:
Removed everything again...
Bam! put that shit on (while cussing up a storm)
Ok put loctite back on all the bolts and put it all back together
After cleaning the trans tunnel a bit... The trans went back in (just like before the top two bolt's on the bellhousing is alot easier reach from inside the engine bay) Bolted the Drive shaft loop back up too. (no issues on anything)
Grabbed the starter , cleaned it and bolted it back up (no problem) Just had to take the studded motor mount bolt off to fit it in. Then put it back. Headers fitment really shines when everything goes in smooth.
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
Gotta hate it when you button something up only to see something you forgot...
I'm loving how easily some of this stuff is bolting up so far.
Matt D
S197 Pilot
Toronto,Canada
Ok so after lunch I walk over to my 3 valve motor on the stand and remove my Ford racing AC elim bracket / pulley. I line it up on the new 5.0 motor and it bolt's on perfect! At this point I am happy as hell :roflmao: (one less thing to buy)
But then.... Im eying down the pulley and it's inbetween the first and second set of ribs on the crank...... :idea:......
Bam lol Then I relize finally why there is two belts... one to run the ac..... Better yet.... I don't even need the ac elim! :roflmao: Less weight FTW :roflmao:
So I walk back over to the 3 valve and bolt it back up lol...
Grabbed some line andmade my vent tube for the cell to the chassis
In the mists of running the lines
The little blue -8 to -6 adapter off my fuel cell will be changed to black (on order) the blue one is what I could grab the fastest for now. So I drilled two holes one for my -6 return line and one for the tank breather. Everything so far on the fuel system isn't tighten up or finallized but you get the idea so far.
Starting to run the lines along the frame...
I thought of so many ways to run the two lines but going from above each other to beside back to above each other was what made me the happiest.
Im not done running the lines but in this pic im holding them against the frame so you guys can see what it will look like
Matt D
S197 Pilot
Toronto,Canada
I was done for the night but before I left I had to do one thing..... Grab the cold air and put it on just for a good look and to keep me motivated :roflmao:
My Man Jay @ JLT Makes some badass parts. There was only one cold air that came to mind with this new project.
I swear I didn't think it would fit under the dam hood because it's so massive :roflmao: I grabbed the moroso fuse boxcover and coolant tank just for the pic :p
All in all I felt like today I didn't get much done, I was feeling a bit wierd and fustrated but some things just take time. I hope to get alot more done tomorrow. But looking at these pics.. I guess it is coming together
Matt D
S197 Pilot
Toronto,Canada
Did you already replace the wiring harness matt?
Not yet, My goal is to remove all the interior stuff (scrape & paint the floors) at the same time put the harness under the dash and make everything fit the way I want. I will take lot's of pics when that happens.... soon I hope ;)
psfracer
billy badass
Valencia, CA
Just got home about 15 mins ago. I woke up a bit late today and kinda started out on the wrong foot....
Well maybe you shouldn't stay out all night drinking and God knows what else......
I havn't taken a close look at the back of them motor because of the engine stand but I just relized the crank trigger is in the back now. Pretty trick stuff from ford.
That is awesome--I didn't know that. That is pretty trick.
Matt D
S197 Pilot
Toronto,Canada
Yeah you better pick it up Matt, your slacking, I wanna see this car running by the new year.
Your killing me bro lol.... It wont be running for a bit, Still waiting on fittings and some other small things... But Im trying to get it done ASAP Beleive that.
GrnBullitt08
Dale Jr
Northwest Indiana
Haha. I'm just messing with ya. I can't say much, my car is still on stands since early November, I have all the parts in now just need to put it back together... All the holidays and laziness has got the best of me.
Wicked One
westchester NY
Bad ass man!!!!
I am looking to just forge my motor and throw on an e force. Great job so far, always enjoy reading you progress.
ScottsVaporGT
Akron, OH
I wish I had the knowledge to do this kind of stuff like you! This is simply awesome!
lol that and a boatload of money!!
Great job Matt, so far what has given you the most problems, and consumed the most time? You seem to be cruising along really quickly and I am surprised at how everything 'seems' to be bolting right up. You are really making it seem fairly straight forward to make this swap. I am just curious on any 'problems' you might not have posted.
RetroGT2006
06 S197 Member
Florida
Forgot to answer the first part lol , Yes I am trying to get it done for the florida race :p Im tired of all this dam snow & Cold weather! :roflmao:
When is this race at Bradenton?? I want to be there to come check your car out in person!
Matt D
S197 Pilot
Toronto,Canada
The only thing on my build that is the most time consuming is all my "custom race parts" but as far as the actually 5.0 swap everything has been amazing so far. Everything Ive learned ive been posting to see how many parts you can save off what your currently got. Im even re using my stock clutch lol. If I have any issues you guys will be the first to hear about it.
Maybe when im all done It might be good enough for a sticky thread
