Young Punk Build Volume IV - The game needs change & I'm the mother *@#%en cashier
oktw88
Oklahoma
so how did you get the car to start with the odometer unplugged since it will not start once you unplug it? The only ones I have seen work are theses gauges with a standalone unit like the fast or BS3?
I have a pump gas 521 big block that is getting put into the car
Towelly
Just saw this out on the interwebs, would be pretty easy to do with a S197 cluster me thinks.
Just a lil' FYI.
00colburn
sacramento
i have been reading ur build since the beginning and it is awesome
i wish i had the money to do this and a shop to work in so i dont have to work outside in the fun elements that i have
but reading this makes me want to put a 4.6 in my 4.0 and do some other modifications to my car
GI Joe
exactly my point...for those considering doing this you have to remember that you will not be able to do it and keep the stock ECU...
sportinawoody
Piedmont area , N.C.
being that the plugs on the ecu are the same and the ecu's are built the same, dont you think swapping pins, adding pins here and there, etc, might be a possibilty to make this work with the gauges?
Fallenauthority
La Plata, MD
Or if you could take apart the stock cluster and tuck the part of the harness with the odometer on it away somewhere in the dash it would work I imagine.
mineralgraygt
the pcm are different. they use diffent software altogether it not like the software in any of the previous year cars. from what ive read is that you can swap the dash and dash harness for the 2011 gts to make it work
sportinawoody
i dont doubt the software is different but the language is the same, so there should be a back door method, just wondering who/when it will get figured it out.
moostang09
Resident YouTube Guy
Mansfield, Tx
It's killing me not having any updates in this thread when I wake up/ go to bed! Lol! Doing big things Matt!
sportinawoody
no updates means matts throwin down hopefully. me an some buds are planning the trip to bradenton partly to see matt run this car. this going to open the door you guys, before long, we should be seeing 5.0 4v's in our shit with a/c
Matt D
S197 Pilot
Toronto,Canada
Im waiting for a bunch of parts :p Im thrashing to get it done for Florida, I want to unload it off the trailer and make a full hit first pass
