3v engine savvy guys step in please
DVEST8R
I have a 5.4 3v short block sitting around collecting dust and have an idea. I have a very good machine shop and im thinking of having the block sleeved to a 3.7 bore. With a stock stroke/rod legenth im looking at 358 ci. Will likely deck block/heads to compensate for the piston being further in the hole. With the right h/c/I combo can good power be made 7-7500? What power out put could be expected with say 11:1 compression?
retfr8flyr
The Old One
Providence Forge, VA
I think it would be much easier to pick up a set of 4v heads. That way everything for the GT500 would work on the setup. With the 3v heads you're going to need a custom intake and exhaust manifold setup.
G.T
Earth
if you're thinking of using that 5.4L Block with the 3V heads.. the only way forward will be a custom sheet metal manifold.. or something out of a F150 :S
Department Of Boost
Alpha Geek
You will need some pretty big cams to feed that 358. And ported heads would help a lot too. Making the motor bigger without improving cylinder filling doesn't do a whole lot of good.
You can use any 4.6 3v intake, it will just need some adapter plates. They would be pretty easy to make (with a CNC). I have all the drawings in CAD to be able to put some plans together in no time.
With ported heads, cams, etc I don't see why it can't make 450-460 ish. But it will cost you way more than putting a blower on it.
DVEST8R
NO adapters exist to make the 4.6 3v intake work?
SStang
I've always wanted to do a 5.4 3V! I know you said 3V, but if you use the 4V heads, you can use the Boss intake with adapter plates from MMR, or weld some tabs to the heads, to bolt the intake down. I'm not sure if the price of sleeving the block would be worth the price. Could use that money buy a good set of custom cams.
SStang.
BruceH
BBB Big Bore Boss 322
Custom pistons with a proper compression height would take care of the .122 in the hole a normal 5.4 is. 1.300" -1.340" would do it I think. There might even be pistons available that are close to that compression height and bore. IIRC some GM motors are fairly close. You could spend some time on Summit and see what's available.
s8v4o
What would a set of plates cost out of curiosity?
Department Of Boost
Alpha Geek
I would guess $600-750. They would be a "one off". If they were a production unit and I could run 20 they would be about half that.
In theory that could be done by hand (not CNC) for less then $600-750. But they would be "prototype" looking.
