3v swap troubleshoot
Discussion in 'Hardcore Tech=*MOTOR SWAPS*' started by Bodvar, Mar 25, 2020 at 9:33 AM.
  1. Bodvar
    Bodvar Junior Member
    22
    I just swapped a new 3v into my 05. The old one didn't have any major modifications and it just has a Borla exhaust, Bama tuner, and cold air. You're basic stuff to get you the 200 extra hp you want... Anyway, I got the swap done and everything seems to be in order. The engine is running lean though and when the tune is put back in stock, it starts and dies. In a 93 octane tune, it runs and drives but it stutters like it's lean. I checked the engine light and it does confirm that it's lean. This light isn't on all the time even when it stutters. Everything like the injectors seems to be working properly, they did operate perfectly before the swap, and I changed my gaskets out. My experience on anything newer than a foxbody is extremely limited and I'm looking for any ideas.
  2. Dman64
    Dman64 Junior Member
    Is there anyway to log your fuel or see what you O2 sensors are reporting? Any idea what your AFR or Lambda is with the 93 tune? What are you running for a fuel system?
    D
  3. Juice
    Juice forum member
    719
    91
    Put the stock airbox in with the stock tune. I suspect your CAI is a "tune required" one.
  4. Bodvar
    22
    I've run it in stock with the CAI it has in it now before. Even then it still sputters down the road with the tune I've had on it.
  5. Juice
    Juice forum member
    719
    91
    Any pending codes? Fuel pressure ok? Clogged fuel filter? How fresh is the fuel?
  6. Bodvar
    22
    I can try to find those numbers on my Bama tuner. In moments like these I really just want an old carb
  7. Bodvar
    22
    Code just shows lean in bank 1, which just confirmed for me that it's lean. Put in a new filter because I had the same thought. Fuel pressure is also good and the fuel was about 2 months old but I put 10 fresh gallons in yesterday.
  8. Juice
    Juice forum member
    719
    91
    In that case, if it is just one bank lean and not both, it maybe an upstream O2 sensor issue on the lean side.
  9. Bodvar
    22
    Drove it around now I get a rich on bank 2 code.
  10. Juice
    Juice forum member
    719
    91
    Do you have a way of viewing live pcm data? If not, you could swap the two upstream o2 sensors. If the code moves with the sensor, you have a bad o2.
  11. Bodvar
    22
    but how would that help if now I'm getting codes from both those sensors?
  12. Juice
    Juice forum member
    719
    91
    You said only bank 2 was lean. Thats why I suggested swapping sensors.
  13. Bodvar
    22
    No sorry for the confusion. Bank 1 was showing a lean code. Now bank 2 is showing a rich code
  14. Juice
    Juice forum member
    719
    91
    That is really strange. O2 sensors wires swapped by accident?
  15. Bodvar
    22
    No it's all in where it goes. I had the thought that this new engine has parts that are upgrades like a new set of cams.
  16. Juice
    Juice forum member
    719
    91
    One side rich and the other lean. I dont think that internal engine mods would have that effect.
    You can always do the basics, pull plugs and do compression check. If any one plug looks different than the others, you have it narrowed down to which cylinder isnt happy.
  17. MrBhp
    MrBhp Member
    61
    20
    Was it a full long block with all accessories swap? Or did you use the original intake?
  18. Bodvar
    22
    Full long block with accessory and intake swap
  19. MrBhp
    MrBhp Member
    61
    20
    I'm sure it's obvious why I asked. Those issues you're having can be caused by a bad intake to head seal. Yeah, as stated before, read the plugs. That will tell if you have an actual lean condition of if you have a sensor issue, or both. If the car is running poorly as you state you're probably going to find some sign of the plugs, which really won't tell you the problem, because the computer is trying to compensate for erroneous data. BUT, it's a start if you have a particular hole that's dry. Could be a bad or clogged injector. That would be awesome if it was that easy.
  20. Bodvar
    22
    I made plans to go over my plugs again when I get home from work. I'll also look for a vacuum leak and a bad intake gasket. The gasket is new so I don't expect that.
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
