550 hp @ 22 psi wtf? On e85
05stroker
Never enough power guy!
Bullard Tx.
I use the two alt bolts on the block and the top two trans bolts put in from the valley side. I pull it out the top with the headers and motor mounts on. If you have a stock k member it is easier if you pull the motor mounts.
swflastang05
Back for More
N. Ft. Myers, FL
^^Exact same method I do it, also using the HF load leveler on these four locations.
palanza7
may just try selling the short block and buying a new 5.0 stroker assembly for my old alum block i have
NUTCASE
I read the 1st page and skipped the rest so if I say something a bit off than oops.
Your first problem is the hardest one to fix. Its your CR. using below 9 compression comes from the old days when we did not have computer controls, did have iron block and heads, and did not have high quality fuel.
you have computer controls, aluminum block and heads that transfer more heat than iron, and you are using e85 which actually favors higher compression.
Also sub 9 compression numbers come from when full race heads flowed what street heads do today. The harder it is to get exhaust out of the piston the harder it is to get heat out of the cylinder.
Also once you get to the upper end of the spectrum on any air mover you start pumping more heat and wasting energy on cavitation.
P.S. you're not alone. When these motors first came out in mustangs there were a lot of people who's first move was to pull the whole motor apart and put in low compression pistons for boost. Then they all couldn't figure out what the deal was on why they could not make the power they were expecting.
Department Of Boost
Alpha Geek
Who's going to buy a 8.8:1 shortblock? You have the motor out. Get some 10:1 pistons, have the it balanced and put it back together.
palanza7
Yeah good point. Mise well keep it simple. Hoping MMR decides to do the right thing and replace the pistons for free. They are closed until Jan 1st
46addict
13726548
Lawrenceville, GA
I would not be counting on that. This is what is likely to happen:
MMR will say you should have asked for a remedy before the engine went together. They will do zip for you.
palanza7
well they would have a point. should have verified. being that it was my first time I didn't even think to. oh well heres to trying.
NUTCASE
Well I'm glad I subscribed. I have never built a shortblock however if I received pistons I would just be like "oh cool my pistons are here, let me just put these in the motor"
palanza7
lol right. i mean plus I had someone building the engine for me - never even thought to double check!
1700 dollar lesson fucking learned gentlemen
palanza7
Well, my list of possible changes so far are:
1. fix the compression
2. cam springs and possibly cams
3. go to a different dyno lmao
other than that, if anyone has any other ideas do throw em at me.
Lito mentioned I would see a big boost drop at high RPM if the valve springs wern't holding the high boost. I never noticed that happening.
i mean there are only so many places to look when the engine is running fine. meh will get it all figured out sometime next year ;p
Northwest Subs Chicago
Well, your burnt out and it's time to put a win in the column you don't want to continue this direction. IMO and I know I already mentioned it before but get yourself to a good local engine machine shop. Sure you can now say well I'm in it this far might as well put the engine together myself, Don't, save it for another time. Let the machine shop look this over and decide what you need and what you don't. Have them build you a nice shortblock out of those parts your have and get to business. If your current MMR disaster is iron then take the aluminum block if it's good with and have them build off that over the iron.
Sell off all the other parts to make up some of the difference,
If you ever think you want to buy something from MMR or if your going to quit and buy one of those fancy new cars, let us know first so we have a chance to talk you back down from quiting.:beerchug2:
Many of us have been where your at, it sucks but don't give in yet, the reward is just going to be bigger.
justinsstang
Can you not just sell the TVS, throw on a turbo, and run all the boost?
That's what I would do with 8.8 CR, but I wouldn't have wanted to take it back apart to swap the pistons.
Nothing a big single or pair of twins can't make up for IMO. S&H twin kit has put out some great results on the 3v.
Department Of Boost
Alpha Geek
He's already running "all the boost". He doesn't have a boost problem.
Just skimmed through the thread, but wow so much ignorance on compression and performance, left and right just being regurgitated. OP I really sorry if the peanut gallery in this thread led you to believe increasing static compression is your miracle solution.
Department Of Boost
Alpha Geek
Yeah, the CR certainly isn't helping. But I agree with you. The majority of the problem is going to be solved elsewhere. My bet at this point is cams/cam timing/valve springs.
