8 Deatschwerks Bosch 1500 CC Injectors
lskiller
8 Deatschwerks 1500cc Bosch EV14 Fuel Injectors. E85 compatible. These are flow matched within 2%, individually numbered, and come with flow data from Deatschwerks. They are 40mm oring to oring without the adapter and 55mm oring to oring with the adapters.
**** These are no longer available. ****
FYi the spacers go on the top of the injectors not the bottom. Did you have to swap them to fit the kb?
lskiller
I don't know what happened to the pic. I modified it to show they were no longer available and the pic went away. I *think* when I talked to them on the phone that they said it didn't matter which end the adapter was on but they definitely sent them with the adapter on the bottom.
