Yes, you are going to die.
Traction control is a band-aid for the masses who drive along with their cell phone in their lap, texting and using their knee to steer. If you actually pay attention while driving your vehicle and are a reasonably skilled driver then you don't need it.
Yes, electronics can make decisions far faster than us humans, but the appropriateness of whatever they do is only as good as the programming (by fallible humans, six sigma efforts notwithstanding) and the database behind it, and the corporate standards, directives. and preferences behind that.I sort of agree with you in spirit, but the computer will react THOUSANDS of times faster than us meat bags can. The brain is incredible in what it can do, but reacting to events in the microsecond (or even millisecond) time frame is NOT one of the things it can do.
And that applies to race drivers as well as us mortals. I remember a (illegal) test a NASCAR team did with traction control back in the early '90s. With the system enabled, they where 2 to 3 seconds per LAP faster than with it off. After running about 10 laps, the brought the car in and removed and destroyed the system as getting caught with it would mean being banned.
So even with drivers that are the best at what they do, with cars that are dialed into perfection for the specific road conditions and a driver that is 100% paying attention and focused, the computer is STILL able to do a better job as it can react so much fast than a person can.
Take it to advance or auto zone, they should have an abs reader to tell you which wheel it is.
You may be able to check continuity through or signal from the sensors with a digital voltmeter.
There may even be a way of producing the code on the dash by shorting pins on the OBD connector. Both of those approaches worked for me on another car. While I can't guarantee success in your case, it's at least something to try. In case you missed it, that's pure tech intended to be helpful. The rest is up to you.
Your continually going to the gutter for things to say at me isn't helping your case. Should you decide to go through moderation, they might be interested to know just who threw the first stone.
Norm
Yes, you are going to die.![]()
Section 206-09 in the shop manual (at least that's where it is for 2008). There's an online version at some I think foreign iihs site that I can never remember all of.
Norm
Thanks for the tech help. haha At least charlie offered me 50 cent in fuses.
why dont you guys go get some voltage values for me![]()
ok, let me start by asking what does abs stand for?
If I were you and that $199 scanner can read more than just powertrain codes, I'd buy it, especially if it has enough of a display to show a brief code description instead of just the code itself. This and one or two more diagnostic sessions avoided will pay for it. And it'll probably be update-able - the Actron unit (9145 ?) I bought a few years ago is, and I probably should.Bingo!
There looks like so many areas that could cause an issue.. I think Ill try to call around some repair shops to see if they have the scan tool and maybe ford..
... thanks
That play is over, the ball is dead and the whistle has blown. Making late hits isn't my thing.Now you can hammer away on me. haha
