So my base model 12 doesn't have satellite radio However, the radio has a button for sirius. When I push it the screen says no sat radio. Is there a kit to buy that I can use with the factory head unit to add it?
You will either have to buy the FORD box and cables to plug it in (which sounds expensive) or buy the Sirius unit from Sirius that uses the FM modulator and mount it some where.
sorry to bring up an old thread, but figured this would be better than starting a new one. Anyways, is this the kit needed to accomplish the job? And I assume it would work on '13 as well.
This is the kit I was looking at. You can find them all over ebay. Didn't know for sure though if they work. I want to keep the stock look so this would be perfect.
The I simple should work just fine. Or as stated get the parts from the ford dealer and use that. Just put a factory one in last week. Sometimes the I simple ones can be kind of tricky to learn the programming. It's been awhile since I have done one.
I just had a customer bring me the factory parts to do It for them. Literally plugged in behind the radio ran the antenna and was done with that part.
The I simple stuff I have used. Just seems to act weird or will stop working for no reason. Them you have to go back in and reset the device by unplugging for a few minutes. If you plan on getting it. Make sure it comes with a scci tuner. They are getting hard to find. Because they are being discontinued soon.
